Question about hose mod.
Originally Posted by Divergent Lightning
cut the hose in half and line the top of the spring with the hose.
yep, grease then twist the heater hose as you slide it onto the spring.
Only do first full coil and leave a little extra hose on the tip to avoid metal to metal if the spring shifts a little.
Also, I remember reading somewhere that the tip of the top coils should be facing the drivers side. Don't know if it really makes a difference but I did this and mine worked out fine.
