Ninetres's new forged 364 build thread
The rebuild has begun!
TSP iron 364
diamond pistons
Callies rods
GM 6.0 crank
Hand ported patriot stg 3 cnc LQ9 heads
T76gts
4" dp
Rossler terminator 2 TH400
PA racing chromoly kemeber
pa racing manual rack
9" w/ 3.25s, strange alum center and strange ultra-light spool, 35 splines
madman tq arm, wolf dbl adj chromoloy lcas and panhard
dual 255s with a -8 feed
I will bump this thread when new pics are uploaded every few days. Also happy to answer any questions you all might have! Enjoy!
http://calibercustoms.com/cagle_camaro_2.htm
Here is the previous build on my stock bottom end:
http://calibercustoms.com/cagel_camaro.htm
TSP iron 364
diamond pistons
Callies rods
GM 6.0 crank
T76gts
4" dp
Originally Posted by Got Me SOM
should run hard, are you making this a race car pretty much?
The cam is definitely speced to be just a cu^t hair below a full race spec cam. I am planning on driving it quite often...but I do have a little acura cl that nets me 30mpg for the rainy days
I should be bumping this thread tonight with more pics.....rear end and fuel system are done, rear suspension is done, motor is dropped and the new block is 90% assembled (with new dual chain...cam etc....) about ready to go in. Texum speed sent me the wrong head studs so I had that mountain top company send me some since they get here in 1 day. My mechanic is going to fab me up some gangster solid motor mounts that should allow a little extra room for that big down pipe to float above the k-member!
Originally Posted by 99Z28LS1
such a sick car and you ran some bad *** times with a STOCK LS1..... sweet ride man
NEW PICS UP!!!!! Madman tq arm bishes. Pretty trick custom brackets and gussets too! Also pics of the old and new block
Nice looking. Can you get us a shot of the passenger side of the engine mounted on the UMI k-memebr. I want to take a look at the clearance for a DP. I wouldnt mind picking up one of those k-memeber's being the rest of my car has UMI pieces.
It looked like a 3.5" DP with the UMI might even be too big. No way a 4" would fit with 6.0 manis.
The UMI was also quite a bit heavier than the PA racing.
Originally Posted by 2002/Black/SS
im talking about dailydriverness, like what rpm is a th400 at 85 etc... and the fun factor. is it worth it?
I have 3.25 gears so my RPMS will be a little more tame than Mr Pres's with the 3.50s.....and his rpms are manageable. I also only have a 3200ish stall so it isn't too high.
85?????? I won't be cruising at 85 on the freeway anymore, more like 60 now to keep the rpms down. Its give and take. I didn't feel like blowing through clutches once a year anymore either.
The fun factor will always win in a 6 speed. You have fun at the track going 10s.....and I will have almost as much fun gong 9s-----get it? At least I still get to shift on a really cool lookin pistol grip shifter, lol!
Originally Posted by ninetres
"dailydriverness" lololol
as for the clutch problem i see what ur saying, thast y i have a twin disk
also, ive never been in a th400, how fast do they shift when u change gears? they have 3 gears right?
whats an example of the rpms ud be at, at 70 on the highway?
A twin disk will be dust in no time if you race a lot and make BIG horse power. Also, a fully built T-56 will take a beating once you get up above 900rwhp.
A TH400 shifts INSTANTLY. The throttle blade also stays open the whole time so there is ZERO turbo lag between gears. Yes, they have 3 gears.
I understand completley on the UMI K-member. I have a old profab unit I may use. I have a 3 inch down pipe and exhaust right now that I plan to run for a while. Once I get al little more serious with the car I amy put the tube k in and run a 4 inch DP.
lol, dude, my car is in pieces as you can see in the pics I posted a link too. I have no clue where my RPMs will be at. If that is your major concern buy a saturn and drive across the country in it a 2k rpms, lol.
i just thought ud know ur rpm on the highway by comparing it to tondss
anyone know where i can see a video of someone driving a th400 on the street normally???
