Ran car w/ ET streets
Old 03-16-2007, 03:50 PM
billybadd's Avatar
Default Ran car w/ ET streets
So I bolted on some 15/8 prostars with 26/11.5/15 ET Streets yesterday and took the car to the track. Tires are dead hooking and now the car is bogging.
Its an a4 w/ 3:73's and a SY 3500 yank converter. I went from 1.8 60ft with nittos to 2.0 with the ET's. WTF! What gears/converters are you guys running with Et streets or drags.
Old 03-16-2007, 05:44 PM
SLPSS99's Avatar
If they are hooking that good then add some more tire pressure, thats what I would do.
Dan
Old 03-16-2007, 06:38 PM
billybadd's Avatar
Yeah thats what I was thinking. Maybe a little 75 wet shot out of the hole too.
Old 03-16-2007, 06:52 PM
junior28570's Avatar
More power
Old 03-16-2007, 07:30 PM
purdueranger's Avatar
I cut a 1.58 60' in a M6 with ET streets and only a 1.79 with my Nittos. Try adjusting the tire pressure.
Old 03-16-2007, 07:59 PM
billybadd's Avatar
They were set at 18 but Ill try to a little higher.
Old 03-17-2007, 04:59 AM
ArrestMeRed99Z28's Avatar
bigger stall
Old 03-17-2007, 05:45 AM
00SS4780's Avatar
I had a SY3500 and the car cut 1.76 but that was all. It just wasn't a big hitting convertor off the line n/a. Now throw a 75 shot on it and it will wake up. I say go with more presure in the tires. That is about all you can do unless you have the $ for a bigger convertor.
Old 03-17-2007, 09:26 AM
billybadd's Avatar
Yeah Ive got a friend trying to talk me into 4:10's but I dont think they will do much different from my 3:73's. Maybe a PT4400 or a Yank Nitrous converter, think its the PY3600?
Old 03-17-2007, 09:58 AM
SLPSS99's Avatar
When I have ran those tires I had good luck at 22psi.
Old 03-17-2007, 12:15 PM
billybadd's Avatar
Im going back out tommorrow and bumping up the psi a bit and spraying the old dog out of the hole. Ill let yall know what it does.
Old 03-17-2007, 12:32 PM
Phoenix 5.7's Avatar
how are u launching? from idle or from like 1500? or from 3500?
Old 03-17-2007, 01:25 PM
00SS4780's Avatar
Good luck with it. I don't think the 4.10's are what you need to 60ft better. That convertor was made to hit softly and not fry tires. I would say get the ss4000 after watching several local cars her just wake up. One lady here put it in hers (I can't remember what convertor she had before) and it cut's 1.50 60fts on 17" M/T drag radials and cam only. That is one killer convertor. I still think the more psi is all that will help you right now. Just air them up high and you can always take them dow. Let us know how it does. Later...
Old 03-17-2007, 06:37 PM
billybadd's Avatar
I tried launching at like 2.2k then just flashing it but same 60ft.
Old 03-17-2007, 06:41 PM
billybadd's Avatar
yeah ill check into that converter. I know the py3600 is a awsome n20 converter but yanks website says that on the motor it is like the sy3500 so I would still have the same problem ya know. Im fixing to cam the car with a MS3 so I want to run alot N/A too, not just on the bottle. What I can say is that the Daves plate kit did give me 4 tenths and 6 mph with just a 75 shot. I guess thats pretty cool.
Old 03-19-2007, 07:56 AM
billybadd's Avatar
Default Update
Ran car at track last night and had better results. 20 psi in the tires, N20 on at 2000. 1.74 60ft., 7.74 @ 90.15.
Im gonna leave that converter in for a while to see how it reacts to a cam. Cam comming in a couple weeks.
Old 03-19-2007, 07:58 AM
00SS4780's Avatar
Nice and thanks for the update. Good luck with it.
