ls1 in 68 c-10 pickup
https://ls1tech.com/forums/conversions-swaps/412057-my-68-ls1-shortstep.html
https://ls1tech.com/forums/conversions-swaps/309481-68-c10.html
https://ls1tech.com/forums/conversions-swaps/370781-my-ls1-t56-swap-into-68-chevy-c-10-stepside.html
are a few i know about...not to hard, to make it fit.....costs about 2x's your budget.
Originally Posted by 1great68
anyone put a ls1 motor in 68 c-10 pick up if so what did you have to do to get it in there.Was it hard and how much did it cost
I'm going to disagree with a few of the thoughts above, especially the radiator. It's not as 'perfect' as a fit as it could be, and the stock '67-'72 radiator is more than sufficient. The F-body fan shroud and fans are worth getting if they're cheap, though. It's not hard to make some very simple brackets that hold it up perfectly.
I've done two. One in a 69 1/2 ton and one in a 67 3/4 ton. First one is a LS1, second a 5.3 with a 1992 five speed truck trans behind it.
I use a carter P5000 fuel pump and get a sending unit for the stock tank from a 71 or 72 that has the return line in it, and run the return line through the bottom of the cab beside the original suction line. I get a cable actuated throttle linkage from the same year trucks, mount it and drill a hole for the cable. I fab the 1/4inch steel adapter plates myself and use your factory 68 engine mounts. Any chevy bolt pattern trans will bolt up. You will need a special flywheel and pilot bushing if you want to run an old style 3,4,5 speed trans. I use the stock rad. With the 5.3 out of a truck, that fan works great. With the LS1 i used the stock fans. I use the stock harness and modify it myself, and I use HPTuners to program out the VATS and modify any other parameters. I use an adapter to connect the new style power steering pump to the old style hoses. Well worth the swap in the end.
Yeah, but he's putting it in a '68 C10 - the factory radiator works fine for the LS1, and unless the old one was totally trashed, he's probably got one. The Camaro fan shroud / fans works fine on the '67-'72 radiator.
