opinions needed
Old 04-05-2007, 11:50 PM
WHITExREAPER's Avatar
Default opinions needed
Okay I need to replace my lifters. So I think im gonna go with ls7 lifters for $135.99, harland's 1.7 rr's $399.99, ARP head bolts $139.99, stock push rods. Now would any of you guys do anything diff? Still mixed on head and exhaust gaskets. I was readin an i seen alot of bad on felpro.
Old 04-06-2007, 12:54 AM
SSilverSSurfer's Avatar
just stick with the stock exaust gaskets, ive had them on and off and have had no problems with them
Old 04-06-2007, 05:46 AM
quick346's Avatar
I would use the GM performance head gaskets
Old 04-06-2007, 05:47 AM
quick346's Avatar
Default lifters
Also the caddy lifters are not much more. you can get them at byunspeed for like 200
Old 04-06-2007, 06:31 AM
King James's Avatar
I personally wouldn't waste the money on the ARP head bolts. It seems like you really don't have a need for them and you can buy a lot of stock replacement bolts before you equal the cost of the ARP's. But that's just me.
For what appears to be a basically stock motor (according to your sig) the Fel-Pro's or Victor Reinz gaskets should be just fine.
Old 04-06-2007, 06:42 AM
cowboysfan's Avatar
since your removing heads I would go with thinner gasket, cometic. gives you a little more compression and throw in a cam. stick with GM Perf. bolts . same for exhaust.
Old 04-06-2007, 09:29 AM
bczee's Avatar
Suggest you replace the push rods with something better. Too many have bend stock one. Why chance it if your down that far.
Old 04-07-2007, 12:55 AM
thanks for the help. Im gonna use the stock rods cause i would rather bend a rod then bend a valve.
Old 04-07-2007, 01:16 AM
00slowredz's Avatar
couldnt have said it better myself
