Help Hptuner guy!!!!!!!!!!!
Ok I got 2 laptops working here
I have my orig tune from when I first read my my ECM. I saved it. Opened it up went to the main VE table copyed it. Went to a file we had already created a 2bar in. Well we messed with it alot till we found out we had a 1bar not a 2bar map sensor.
Ok with that said here is the deal. When I copyed the orig file main VE table and stuck it in the main ve table on the 2bar. Well I look on the far left hand side of the table where it says manifold absoulte pressure (kpa) it starts at 30. Not 15 where it should be. The tuner messed with the file before I got ahold of it.
So the question is how do I get it back to 15 on the far left where it reads manifold absoulte pressure (kpa).
If someone has the time please feel free to give me a call. 832-866-7406. I am sure its a quick fix. But I just want to make sure I got the little things worked out because we played with the tune alot.
Thanks
-Tim
Thanks
-Tim
LS1TECH Sponsor
Originally Posted by 1INSANEGTO
When I first scaned the ECM the first time it was 15kpa. I was refering to the 15kpa because thats what it is on the demo on hptuners for putting the car in 2bar
Here is the file
Here is the file
The stock OS starts at 15kpa, but not the 2 bar.
