Help Hptuner guy!!!!!!!!!!!
Old Apr 10, 2007 | 06:27 PM
1INSANEGTO's Avatar
Default Help Hptuner guy!!!!!!!!!!!
Ok I got 2 laptops working here
I have my orig tune from when I first read my my ECM. I saved it. Opened it up went to the main VE table copyed it. Went to a file we had already created a 2bar in. Well we messed with it alot till we found out we had a 1bar not a 2bar map sensor.
Ok with that said here is the deal. When I copyed the orig file main VE table and stuck it in the main ve table on the 2bar. Well I look on the far left hand side of the table where it says manifold absoulte pressure (kpa) it starts at 30. Not 15 where it should be. The tuner messed with the file before I got ahold of it.
So the question is how do I get it back to 15 on the far left where it reads manifold absoulte pressure (kpa).
If someone has the time please feel free to give me a call. 832-866-7406. I am sure its a quick fix. But I just want to make sure I got the little things worked out because we played with the tune alot.
Thanks
-Tim
Old Apr 10, 2007 | 08:22 PM
98turbls1's Avatar
Do you have the original new tune that you had before you plugged the new VE tables in?? I would open that one back up and try again... Probably something was augmented that wasn't supposed to...
Old Apr 10, 2007 | 08:46 PM
1INSANEGTO's Avatar
Here is the file...
Yes I know its off...but that was due to a map sensor.
Old Apr 10, 2007 | 08:55 PM
98turbls1's Avatar
I can't see anything... when you initially loaded the 2 bar did it begin a 15kpa or 30kpa??
Old Apr 10, 2007 | 09:05 PM
foff667's Avatar
LS1TECH Sponsor
Some of the later 03+ pcm's just don't have the room in the pcm to allow us to give you the lower map resolution unfortunatly.
Old Apr 10, 2007 | 10:09 PM
1INSANEGTO's Avatar
When I first scaned the ECM the first time it was 15kpa. I was refering to the 15kpa because thats what it is on the demo on hptuners for putting the car in 2bar
Here is the file
Old Apr 11, 2007 | 06:48 AM
foff667's Avatar
LS1TECH Sponsor
Here is the file
im not sure what you mean? the file you just posted is a two bar & starts @ 30kpa.
The stock OS starts at 15kpa, but not the 2 bar.
Old Apr 11, 2007 | 07:46 AM
1INSANEGTO's Avatar
Ok thank foff. Now I uderstand. Can anyone tell me how I look fuel wise? Becuase I know we messed with it alot. Just need to know any changes I need to make before start.
