ls1 402?
ls1 402?
Hey is it possible to bore my sleeves to 4.00" and put a 4" stroker crank in it without re sleeving. Iam looking for a cheaper way to build my 402 that buying a ls2 block. I searched and couldnt find any info on a ls1 402 just ls2s. Any info will help thatnks.
LS1TECH Sponsor
4" bore
The machine work alone to install the sleeves would cost more than a new LS2 block. The least expensive way to a 4" bore would be an iron block unless you can find a good used LS2 block.
Steve
Steve
Originally Posted by 1slogto
damn i dont want to have to buy an ls2 or resleeve the ls1. Does anyone know how much a set of 4.00" sleeves would run me?
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
Ive seen LS2 blocks go for a few hundred bucks used.
Do not try to bore the LS1 out any more than 3.91, the common bore for the LS1 is 3.905.
I think the C5R block is the only way to go w/ a bigger bore. IIRC, you can't punch the LS1 stock block. Too thin of sleeves.
LS2 can do it w/ a new rotating assembly, I'm pretty sure.
i might be getting a 6.0 iron block from a friend that is taking it out of his truck and parting out the truck. I didnt want to go with the iron block because i already have such a heavy car, but it looks like its time for some more weight reduction.
If i were rich and famous i would go with a C5R block but i cant cough up 6k for a block on its own lol
