cam suggestions??? '97 a4
Old 04-15-2007, 10:02 PM
fastburn's Avatar
Default cam suggestions??? '97 a4
im having my stock heads gone threw and wanted to install another cam while its down.what do ya'll suggest?its a stock '97 a4 camaro.i do plan on installing mods on the car in the next few months.(gears/exhaust/dry kit)i dont have a stall conv in the car and probably wont for awhile.its a ddriver.
also i plan on changing the valve springs too.let the suggestions fly!!
post specs,thanks
Old 04-15-2007, 10:07 PM
94'BLKBRD's Avatar
gm847! click sig for vid
Old 04-16-2007, 12:51 AM
siniSSter's Avatar
You quote "another cam." What cam did you have before if you had one? Do you want a real lopey idle. I've got a pretty big cam, and in my opinion its pretty streetable to me. Just do some research, and remember that bigger isn't always better.
Old 04-16-2007, 01:26 AM
97Lt1TA's Avatar
cam gm 847
rocker arms crane gold 1.6
springs comp cam 918
stall 3400-3600
36 lb injectors
those will work great with gm847 cam
Old 04-16-2007, 07:07 AM
fastburn's Avatar
im replacing the stock cam.
im looking for a very streetable cam and as far as the lope goes i dont really want it to sound like a harley.a little lope is cool but im not going crazy with it.
that gm847,is that a gm part#
also whats a cc306 cam like?
Old 04-16-2007, 08:24 AM
speed_demon24's Avatar
The stock cam is as big as you want to go with the stock converter....
Old 04-16-2007, 10:14 AM
97Lt1TA's Avatar
cc306 is the same as gm847 just gm847 is little bit more aggresive
cc503 would be good for you then if you dont a loud cam
Old 04-16-2007, 10:45 AM
Matts94Z28's Avatar
I have the CC306 and love it. But if i were to do it over again i would go custom. Give one of the custom cam guys a call and tell them what you want.
Old 04-16-2007, 10:51 AM
DroppedM6Z's Avatar
The XFI 230/236 576/571. The biggest i'd put in a stock head car. If i was doing it, i'd use the 224/230 XE grind. And PS, you dont need injectors
Quick Reply: cam suggestions??? '97 a4
