Fireball FI98x Turbo Build
Old 04-16-2007, 07:44 AM
Fireball's Avatar
Default Fireball FI98x Turbo Build
1. Project Sponsors
Performance Auto Fabrication, Inc.
Virginia Speed
2. Vehicle year, make, model, mileage
1999 Trans Am 75K miles
3. Current Modifications List
See below
4. Planned Modifications List
See below
5. Current HP/TQ or Track Results
Best of 10.48 @ 129.4 H/C and Six speed
6. Planned HP/TQ or Track Results
1300 FWHP (est)...Low 8s @ 170ish (one can hope )
After wearing out the motor of my stock-bottom ended H/C setup, I decided to start a turbo project.
Found a race class that requires a true 10.5" tire and an 88-mm maximum size turbo restriction, so I chose to build around that class. The specifics will be a .010 over LS2 (stock stroke) motor 366 cid, ETP 225 heads (9:1 compression), vic Jr intake intake and Wilson 90mm elbow. Tranny will be a powerglide. Specific details will be given within...
Step one...
Order some turbo parts. Found a killer deal on tech and bought the following as a package. GT47-88 turbo, Reichard Racing "minicube" A2W intercooler, HKS GT-II 60mm wastegate, Meziere A2W water pump.
Step two...
Hack up the back of the car and add minitubs. I ordered a moser 9" rear narrowed as far as they could go with STOCK SUSPENSION MOUNT POINTS which was 3 3/4" per side (7.5" total). The rear was equipped with optional drain/fill points and a back brace. 35-spline axles, spool and aluminum center round out the package. I still haven't put gears in yet. Wheels are 15x10 American Racing Pro-Series Trakstars on a 5" BS. LCAs are Billingsley Racing Offsets. As you can see in this picture, I still had my old 28x10x15 hoosiers mounted on the rims an no brake calipers yet so the pic looks a bit goofy (tires set in pretty far)...this will change
Fireball is offline
Old 04-16-2007, 07:52 AM
Fireball's Avatar
Step 3 Training wheels Performance Auto Fabrication custom wheelie bars. They are 68 +/- inches long. The third picture is a decent picture of the rear
Step 4 Motor and mid plates, mount the turbo, and radiator. Plates are Madman pieces. Radiator is a universal griffen unit and the front of the car was modified to accomodate it.
Step 5 Air filter. Found this 14" long filter from AFE
Step 6 Headers. Custom 304 stainless forward facing headers. We opted to make them this way to help with routing and it keeps the primaries a bit longer.
Fireball is offline
Old 04-16-2007, 08:01 AM
Fireball's Avatar
Step 7. Real tires. Mounted the real tires I plan to run. 29.5x10.5x15 C11 Hoosiers. Same compound used by the fastest outlaw 10.5 cars (its a new tire).
Step 8. Rollcage. Back when the car was N/A, we built a 10-pt cage that was intended to be upgraded to SFI 25.5 later.
Currently the car is in the 25.5 build stage. Here is pic of the fitting up of the funnycar cage:
Here is a pic of the required under_car bars
Fireball is offline
Old 06-16-2007, 07:00 PM
Fireball's Avatar
Update 6/16
Crossover piping: all stainless
Turbo remounted and majority of the downpipe tacked in place
Fireball is offline
Old 06-21-2007, 07:02 AM
Fireball's Avatar
update 6/21
Added a few more pics of the 25.5 cage:
Fireball is offline
Old 06-30-2007, 05:31 PM
Fireball's Avatar
Update 6/30
Got the A2W intercooler installed. Saw one positioned similarly on another build and I liked it...really tough to get it to fit though...needed alot of cutting
Fireball is offline
Old 07-14-2007, 06:02 PM
Fireball's Avatar
Update 7-14
Got the turbo connected to the intercooler and the Tial 50mm blowoff valve welded up. Note that there aren't any silicone connectors anywhere....everything is connected with aluminum v-band assemblies
Fireball is offline
Old 07-21-2007, 05:32 PM
Fireball's Avatar
update 7-21-07
Fireball is offline
Old 07-28-2007, 02:02 PM
Fireball's Avatar
couple more pics:
Fireball is offline
Old 08-13-2007, 12:14 PM
Fireball's Avatar
update 8-13-07
Installed the parachute mount:
Fireball is offline
Old 08-13-2007, 02:00 PM
Brains's Avatar
That is a really clean build, very nice work!
Brains is offline
Old 09-26-2007, 04:22 PM
Fireball's Avatar
Updated my sponsor info...
Fireball is offline
Old 09-30-2007, 06:52 PM
Fireball's Avatar
Update 9/30
Got the exhaust system layed out today....tacked up, to be fully welded up later...pretty simple design. 4" past the motor plate, under the starter into a 4" bullet muffler then a turndown
Also threw the car on the scales....I figure there is about 500 or so more lbs to put in (tranny, converter, gears, driveshaft, brakes and fuel/water systems mainly)
Came in at a portly 2502 lbs right now
Looks like 3200 lb raceweight is probably an achievable goal...still have about 30-40 lbs that needs to be removed too...(cutting out my old Global west SFCs since the new 25.5 cage has integrated SFCs)...also need to install my tubular A-arms in place of the stockers...
Fireball is offline
Old 10-27-2007, 05:41 PM
Fireball's Avatar
update 10-27
Mounted the belt-drive fuel pump, vacuum pump and connected the wastegate discharge to the downpipe:
Fireball is offline
Old 11-03-2007, 06:13 PM
Fireball's Avatar
Update 11/3/07
Installed the moroso replacement oil pan today....really nicely engineered piece IMHO...
1. Pickup is moved to the back of the oil pan
2. Windage tray now covers the WHOLE rotating assembly
3. The pan is much lighter than the stocker but has a nice thick flange.
New windage tray installed
Windage Tray comparison (stock held up next to installed moroso one
Oil pickup installed
Pan installed
Fireball is offline
Fireball's Avatar
Some more pics of the turbo system
Fireball is offline
Old 11-10-2007, 05:37 PM
Fireball's Avatar
added a little bit of "bling bling" to the motor, also started on the tubular bumper support:
Fireball is offline
Old 12-04-2007, 05:53 PM
Fireball's Avatar
So I up and sold the GT47....wonder whats in store now
Fireball is offline
Old 12-10-2007, 07:16 AM
Fireball's Avatar
Once I get my 7.50 sticker, I'll start refitting the interior panels
Also cleaned it up and got a nice picture of the back end
Fireball is offline
Old 01-25-2008, 03:38 PM
Fireball's Avatar
couple updates:
Got the cage certified for 7.50s
Mounted the stroud chute
Also ordered BS3 and racepak dash setup
Fireball is offline
Quick Reply: Fireball FI98x Turbo Build
