Stb???
You'll be fine with the 2pt STB.
You can get a 3pt STB but the big issue with this STB is that it may result in cracks formng on the windshield due to the additional stresses occuring at 3 connections as opposed to 2 connections with the 2pt STB
If you go with either one, make sure you get one that is a one piece design (ie not connectors in the middle of the bar, no adjustment screws, etc as these will eventuall cause the STB to break)
Chrome Moly is stronger than steel tubing STB's, and they cost a bit more. Get some quotes and see if there is much of a difference in price, if its not that big of a gap, then opt for the chrome moly.
Originally Posted by mighty mike
hey thanks alot hopefully i will get it when its done with the exhaust next week any brand preff.
Best of luck
