What stat you runnin'?
Old 04-29-2007, 03:59 PM
TS6
TS6's Avatar
Default What stat you runnin'?
160 or 180 or ???
Also, what temps do you actually run with your stat?
Old 04-29-2007, 04:04 PM
98turbls1's Avatar
I'm running a 160... When are your fans coming on?? Do you have tuning software?? If so just try to turn it down a bit to accomidate the lower temp...
Old 04-29-2007, 04:06 PM
TS6
TS6's Avatar
Yeah, fans come on at 165 I think. Off at 159 (never happens).
Old 04-29-2007, 04:08 PM
ninetres's Avatar
160 here. Normal operating is ~180--187, but I haven't driven in the dead heat of summer yet. This was with my stock block, I haven't tested out the iron 364 yet. Wednesday though my friends.....Wednesday
Old 04-29-2007, 06:11 PM
TS6
TS6's Avatar
Hope you have better luck than me! I think that iron block is harder to cool than the aluminum. The extra displacement doesn't help matters either.
Old 04-29-2007, 08:00 PM
Ed Blown Vert's Avatar
160 Stat with the fan @ 190
Old 05-08-2007, 04:12 PM
FastKat's Avatar
I just ordered a 180. I figured if the cooling system couldn't support 160 degrees consistently than why bother trying to hold it there? I think I'd rather try to stick with something consistent than go for something super low. Also, I don't want any check engine lights and I want the option of having heat.
Old 05-08-2007, 08:39 PM
BigJls1's Avatar
160* water will still blow hot air .stick your finger in 105* water, you cant hold it there.
Old 05-08-2007, 08:56 PM
rmpage's Avatar
Personally I would stick to 180, if not the stock temp. 160F is low enough that lubrication efficacy starts to disappear. For wild temps, a bigger radiator would be my choice.
