shortening Ti valves
The only reliable way this could work is if the new overall length is equal to or lower than the bottom of the existing keeper groove. If the valves currently have square grooves then they'll have either a .250" or .290" tip length. After machining, the original groove will then be just below the new tip end. Not good............
If the valves have bead lock grooves they'll also be up near the tip of the new valve length.
Richard
Richard
