??? about f1 procharger..
Old 05-11-2007, 11:34 PM
ASkipper's Avatar
Default ??? about f1 procharger..
What is the least amount of boost that can be ran with the f1 procharger? I am thinking about buying one.
Old 05-12-2007, 12:43 AM
dixonk's Avatar
I believe you can boost as far down as the p1 or d1 if you choose to put that big of a pulley on. I believe the size is a 4.33. But why would you want to buy an F1 if you don't plan on going over 12 psi?
Old 05-12-2007, 12:30 PM
marco427's Avatar
I'm running 8 psi on an F1C until I 1.get used to 773 RWHP and 2.Install a meth system.
Old 05-12-2007, 12:40 PM
HUNTER02SS's Avatar
On a 347 it might only be able to go as low as 10 or so .Depend's on his setup.
Old 05-12-2007, 02:20 PM
kbronSS's Avatar
whats your setup? im getting a 427 very shortly with the D1.
Old 05-12-2007, 03:38 PM
ASkipper's Avatar
Car in avatar.Mods are headers ORY.Stock engine. I plan on going all forged later on but I can buy a F1 kit here
https://ls1tech.com/forums/lsx-parts-sale/711918-procharger-f1-kit-f-body.html
Old 05-12-2007, 04:04 PM
98turbls1's Avatar
Do it... Just put the biggest pulley that you can and then if your motor still goes then it's meant to be with the forged engine... Just run little timing and lots of fuel to get you through... You may also look into some meth...
Old 05-12-2007, 04:55 PM
Hennytime's Avatar
you could also run a cam with alot of overlap to bleed off some boost, that might help in keeping ht stock bottom end around for a little bit
Old 05-12-2007, 05:57 PM
marco427's Avatar
I'm running a C5R 427 with LS7 heads. The car made almost 800 RWHP at the same 8 pounds of boost with a slightly leaner tune.
Old 05-12-2007, 10:35 PM
Got Me SOM's Avatar
on a stock bottom end with no fuel system you'll be blowing her up very soon.
hey marko did u use all the money you stole from all the members on your hi flo production turbo kit to build that car?
Old 05-13-2007, 12:42 AM
kbronSS's Avatar
which cam? thats the hp im shooting for. as long as i get 700 at the wheels with 8lbs id be happy, that 800 with just 8lbs, i gotta get some tips.
Old 05-13-2007, 06:34 AM
EPP
EPP's Avatar
We had a customer with an 04 GTO buy an F1A from us. He had a 5.75 blower pulley custom made for him as his bottom end is still stock. He ended up with 6.75 lbs of boost. Bob
Old 05-13-2007, 10:32 AM
ASkipper's Avatar
What is the biggest pulley available from Procharger?
Old 05-13-2007, 01:06 PM
kbronSS's Avatar
ill be ordering pretty soon.
Old 05-14-2007, 08:23 AM
andereck's Avatar
You would probably want a 5" pulley.
Quick Reply: ??? about f1 procharger..
