Pulling engine from top???
It will come out nice and easy its going back in that is a pain in the ***. I pulled mine with the heads off. Put it back in with heads on. I tried everything to get that puppy back in. I had to lower the 4 craddles bolt to the end threads to get oil pan wing to clear. Just remember you also gonna need to disconnect the shocks and A-arms,brake lines to lower the cradle no biggie though. You should also dissconnect the power steering line in the center of the steering rack just protect the threads. Recommend doing a clutch at the same time.
Originally Posted by 2MuchRiceMakesMeSick
maybe this will help
i did mine using that link also. one thing that helped me out a lot on the install was making sure the motor was level before stuffing it, (i had to attempt it twice)
