LS1 to LS6
Old 06-15-2007, 12:49 AM
LS1SSZ28's Avatar
Default LS1 to LS6
What all is different, or replacable on the ls1 to make the ls6?
Old 06-15-2007, 02:35 AM
staringback05's Avatar
well the block is different so your not going to achieve that...they have different windows...
however the attachments, include the cam and heads and pistons.....
Old 06-15-2007, 06:30 AM
King James's Avatar
And intake depending on year of LS1
Old 06-15-2007, 09:10 AM
LS1SSZ28's Avatar
oh i guess im a rare one...i looked at the block numbers and im one of the lucky ones to ge the ls6 block...and i have the ls6 intake
Old 06-15-2007, 09:20 AM
LS1SSZ28's Avatar
so far im getting, that i dont have(i have block,intake)
MAF
Pistons
Cam
anything else?
Old 06-15-2007, 09:26 AM
95transamguy's Avatar
heads
Old 06-15-2007, 09:28 AM
LS1SSZ28's Avatar
heads,cam,piston,maf
is that pretty much everything?
Old 06-15-2007, 10:30 AM
WS6NIGHTMARE's Avatar
Nevermind the pistons, get the LS6 H/C, intake and its an LS6. The LS6 block is also negligible over over an LS1 block. Unless you just want to make it an exact duplicate, in which case have at it.
What is the year and make of your car?
Old 06-15-2007, 10:34 AM
LS1SSZ28's Avatar
2001 Camaro SS M6
Old 06-15-2007, 10:41 AM
Originally Posted by LS1SSZ28
2001 Camaro SS M6
Ya, for these years the LS6 intake was standard equipment. The block, well some of them got it, but its nothing to write home about. H/C is all you need.
Old 06-15-2007, 10:42 AM
LS1SSZ28's Avatar
what is an estimate on how much that would cost?
Old 06-15-2007, 11:24 AM
Used LS6 heads usually go for about $500 all the time, sometimes the cam will go with them for about $100 more. The cams dont pop up for sale as often as the heads, but to get it new is only about $220. Plus all necessary gaskets.
Old 06-15-2007, 11:28 AM
Michael02hawk's Avatar
If your looking to 'truely' have an LS6 setup, you'll also need to the LS6 Valley Cover. Since you already have an LS6 block, you wouldnt need to cut the block, simply bolt it on, and re-route the PCV hose.
Old 06-15-2007, 02:42 PM
LS1SSZ28's Avatar
how much would i expect to gain from the ls6 heads and cams?
Old 06-15-2007, 03:07 PM
armkneez8's Avatar
Hey guys what is the code on the block if u have a LS6? Thanx!
Old 06-15-2007, 04:22 PM
Well there is a guy on Tech with just an LS6 swap and if I remember right he makes 410 at the wheels. Plenty of passing power in silent form. But he has all the bolt ons and a tune to top it off. Tune is a must though.
