L92 - milling? PTV?
L92 - milling? PTV?
Anybody know the basic formula for milling the L92 heads to figure out how much to remove equals 1cc of chamber volume?
Also, anybody know where people are having PTV issues with the cams that are appropriate for these setups on say flat top pistons? I'm not changing cams yet, but will run a bigger cam later and would like to know how far I'll be able to mill and be safe, so that I can pick the right pistons.
So its rate is the same as the regular LS-based heads? That's some odd physics if they did that.
And I'm not a n00b. I never said I won't measure, dude. Not sure where you read that I'm not measuring. That's weird. I thought only my wife could take a sentence and get a totally different sentence from it.
I'm asking so that I can plan accordingly AND THEN I'LL MEASURE. I can't measure before I even build the engine. I need to be sure to buy the right pistons.
As far as him telling you to measure. You gave him an equation with two variables. He never told yoy to measure before you get the engine built. He was implying that you needed to measure when you got it built because he doesn't know
1) How much you plan on milling.
2)What pistons you will be using
3)What cam you will be using
As you know all these will play into how much PTV you will have. I would have told you the same thing.
Nice message board arrogance, but come on. There's no need. We know basically what setups can and can't fit before assembly, and for you to pretend we don't is just absurd. For instance: hey can I safely run a g5x3 on a 112 with stock pistons and stock heads? No. We know that. But with a 2cc relief which usually is 0.130+ deep, you can. So let me dumb it down for the wannabe smart kids:
1 - What is the formula on milling/volume? I've seen 1cc=0.010", but nobody said for sure.
2 - how much taller is the L92 head regarding stock valve drop?
3 - how much taller is the L92 head regarding pushrod length (yes in a stock block)?
1 I would go with the .006" per cc
2 The intake valve is .015" closer to the deck (.135" versus .150")
3 The stock L92 valves will not clear a 5.7 stock shortblock
So in short, you would have to mill the heads .036-.042 to get them where a LS6 or 5.3 head is, you would have less P to V then with either of those 2 heads, and you still don't have valves that clear the bore of the 3.90 block.
Did that leave plenty of mounting surface thickness to the deck?
That math shows that:
.040 = 5.8cc
58/4= 14.5
So every 0.010" you mill removes 1.45cc.
.040 = 5.8cc
58/4= 14.5
*If you want to do a clean up later .050 is getting thin
*.040 is about it for the intake lining up with the ports.
You can always use thinner gaskets as well. I used .040 there which gave me a tad over 11:1.
