No cats - need help
No cats - need help
I purchased a car sight unseen on the word of the owner there were no issues, only mods were catback, lid throttle body and wheels.
well, 20 miles into driving it the SES light comes on. I stopped at auto zone and had them read it. P0420 and P0430 - both are related to the O2 sensors... which I found out are not there since there are no cats, I guess it also has the Bassani ORY that the owner failed to mention.
My question is what all do I need to have everything legal again? Im hoping to find a stock WS6 exhaust from the manifold back. If I can, what do I do about the O2 sensors? Should the wire and everything still be on the car?
If I cant find a stock exhaust, can I get Miidas or someone to install 2 cats?
If so, same question - how do I get the O2 sensors to work and read correctly?
Thanks
Thanks
That sucks you need the sniffer. Without the cats it may be hard to pass. Run some of that guaranteed to pass stuff in the gas (dont really know if it works) And wring that sucker out a few times on the highway. Do they not plug in the OBDII there?
If they do a tailpipe test and you do not have catalytic converters, it would be almost impossible to pass. Catalytic converters convert harmful emissions into CO2 and water (not harmful).
if tuned properly an LS1 can easily pass a sniffer test without cats
Theoretically, a perfectly tuned engine that was 100 % efficient would only produce water and C02 (perfect combustion). Unfortunately, "most" engines are not 100 % efficient and do not achieve perfect combustion. That leaves CO, Nitrogen Oxides and Hydrocarbons in the exhaust. A catalytic converter works to clean up these dirty byproducts of combustion and convert them to Nitrogen, Carbon Dioxide and Water. A sniffer test measures all these byproducts and determines whether they are at acceptable levels. Without a catalytic converter in place, theoretically you could pass but your chances of sucess are greatly reduced. Since no engine manufacturer has yet made a prefectly efficient engine that achieves perfect combusion, all vehicles are required to use catalytic converters.
