Critique my potential 408 build
I'd like to get some input on this build that I've been considering. Keep in mind that this started as a budget rebuild of my stock cubes until I ran across a couple of deals.
I am unsure what cam to run, so I'm going to use my current cam and see what happens after that. The reason that I think my G5X3 might be okay is that the intake is seen to fall off sharply after 6300 RPM if you've paid attention to the board. So this small cam (small for a 408) will peter out by then. Sound okay so far? Cam gurus, if you think I should retard/advance it any, let me know. Remember G5X3 is 234/242 .598/.610 112+4 on XE-R lobes.
I am building this to be the strongest NA, street driven but mostly race-oriented car that I can build. To put it into perspective, I love the way my car feels with a 3600 stall and this cam/heads that I have now. So slightly big cam but still good in the midrange. With the torque curves I see coming from 408's, I think midrange will be no problem. So I'm not against a bigger cam if that is needed. But give me a reason.
Also this engine will see some nitrous use. Probably just 100 shot when I run spray, but will consider bigger if I go for a faster time. 250hp shot max.
Iron Block 4.030" bore
Eagle 4.00" crank
Callies Comp Star rods
Wiseco pistons -2.2cc (is paying for coated ones important?)
Not sure of rings... make a suggestion on brand and gap
ARP main studs
ARP head bolts
L92 heads (stock but will get some slight work done)
L76 intake
L76 injectors and fuel rail
Still unsure on throttle body... will get whatever I get a deal on
Lifters... LS7? Stock LS1? Caddy?
Rollmaster adjustable double roller timing set
Eagle 4.00" crank
ARP main studs
ARP head bolts
L76 intake
LS1 Tech Administrator
The low and mid-range torque will be excellent with a G5X3 in a 408. That will give you the throttle response and street manners of a 224/232 cam in a 346. Retarding the cam 4 degrees to +0 is a smart move for power on motor, but not for nitrous.
On nitrous, the combustion happens much faster and the volume is much greater. A 100 shot will not require too much in the way of special cam events but a 200+ shot will. A 200 shot will want around an 8 degree earlier EVO. If the EVO of an X3 cam at +4 is 57 degrees BBDC and you retard it 4 degrees, the EVO is now at 53 degrees. OK for NA, but not for the spray. Ideally, you'd want your EVO to be at 61 degrees BBBC for a 200 shot (assuming 234/242 112LSA +0 was ideal on motor). Keeping the IVO and IVC the same as the X3 cam at +0, but making the EVO 8 degrees earlier (while keeping the overlap the same (14 degrees at .050) means a cam that looks like this: 234/250 114LSA +2. Same IVO and IVC. Same overlap. Same EVC, but the EVO is 8 degrees earlier. Pretty cool stuff huh?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Thanks for the help, PatrickG. Your help is greatly appreciated.
With that info, maybe I'll just go bigger all the way around. 224 manners is NOT what I'm looking for. Having a 4L80e, PY3600, 9", and suspension mods, I'm not THAT concerned with street manners. So basically, if I wanted a cam to act in the 408 like my G5X3 does in my car, I'd need to go something similar to a Trex, only with a greater LSA for nitrous?
Ahh heck, anybody else thinking Futral Godzilla cam? LOL! Just kidding!
For a 408 to have the same street manners and power band as a 346, you'll want to add 10 degrees to the duration. If your intake valve is the same size, you'll be more undervalved which will make your motor want a little more overlap.
Take your 234/242 112LSA +4 and add 10 degrees to it:
244/252 112LSA +4.
Look at the valve events:
14 BTDC IVO
50 ABDC IVC (really good for a 408)
62 BBDC EVO (close to the nitrous recommendation)
10 ATDC EVC
24 degrees of overlap at .050"
Overall a nice cam on and off the nitrous.
244/252 112LSA +4.
14 BTDC IVO
10 ATDC EVC
__________________
Most of the L92 setups have been low compression (below 11.0:1). Get your compression closer to 12.0:1 and run at least a 4.03" bore and the L92s will probably walk all over other heads.
__________________
