best forged rods and pistons?
Old 08-02-2007, 05:00 PM
Black FormulaLs1's Avatar
Default best forged rods and pistons?
trying to figure out who makes the best bang for buck forged pistons rods for a stock Ci LS1..as well as Clevite bearings 77 or federal Mogul ...
I have tried looking on ebay for a complete rebuild kit for my LS1 but nobody offers it..thanks
Gregg
Old 08-02-2007, 05:01 PM
BIG_MIKE2005's Avatar
Best bang for the buck rods I'd say are the Callies. they can be had for under $600.
Old 08-02-2007, 05:07 PM
MM98's Avatar
Diamond pistons & eagle h-beams here.
Old 08-02-2007, 05:09 PM
SoCal01z28's Avatar
manley has their H-beams on sale right now, i picked up a set of 6.125's for $490
Old 08-03-2007, 06:55 AM
Sigforty's Avatar
I am running Diamond pistons with Manley rods.
Old 08-03-2007, 07:11 AM
slow trap's Avatar
compstar rods with mahle pistons in my wheezer. pretty much most of the h beam rods will handle quite a bit of power.eagle,scat,manley. piston wise i guess it depends on what you plan to do with the motor but a regular forged piston like the mahle or similar will handle over 700 rw without any issues imo. if i planned on boosting big or spraying 250 + then is when i would look into a nitrous/turbo specific piston.
Old 08-04-2007, 12:22 PM
sweetness thanks for all the help!!! will start looking into any pckg deals that are out there
Old 08-04-2007, 12:36 PM
KCS
Moderator
KCS's Avatar
You can usually find SCAT or Eagle rods on ebay for about $350-$400. I think SDPC even has forged replacement pistons for cheap too, around $500.
I'm actually getting rid of my stuff, I don't know if you're wanting a dished piston or not but you can check it out if you like:
https://ls1tech.com/forums/showthrea...93#post7557293
Kent
Old 08-04-2007, 03:04 PM
2 SSlow's Avatar
I'm running Scat H-beams, and probe forged pistons. Motor sounds better, and quieter than the stock ever was. No piston slap or any of that ****. Clevite 77 bearings, ls7 lifters, ported oil pump, etc. Holds a nice 45+ oil pressure at idle at idle
Old 08-05-2007, 01:17 AM
racer7088's Avatar
Eagle has great on-center LS1 rods in 6.125 and 6.200 long and Callies has their Compstars in 6.125. These are probably the best bang for teh buck in that order.
Old 08-05-2007, 01:18 AM
racer7088's Avatar
Thumbs up
Probe has the least expensive forged LS1 pistons for the 346. I mostly use Wiseco and Diamond which are a little more expensive but also more robust as well.
Quick Reply: best forged rods and pistons?
