The difference Torquer V.2 vs. Torquer V.3
Old 08-08-2007, 05:40 PM
02 T/A 984's Avatar
Default The difference Torquer V.2 vs. Torquer V.3
ok just curious what is the performance difference between these two cams i know there's a difference in lift and everything but just curious on how the differ in performance
Old 08-08-2007, 05:48 PM
Thorny's Avatar
I am also interested in this. The V.2 has an 1800-6400 advertised powerband while the V.3 has 2300-6700 powerband. I would think that since the LSA of the V.3 is lower that the powerband would be similar since the duration is almost the same. Does the change in intake lift really make that much of a difference.
I'm looking at either the torquer or 228R for a winter project, input would be great.
Old 08-08-2007, 08:50 PM
CodeName Z06's Avatar
I am also interested to see what the different intake lobes really add in the performance area.
Old 08-08-2007, 08:55 PM
blksheep's Avatar
find some graphs of the v2 and the v3 and compare...
Old 08-09-2007, 06:26 AM
Fb0dy0nly's Avatar
call or PM TSP, they will give you all the info you want/need.
Old 08-10-2007, 10:51 PM
'02 WS6's Avatar
my cam only torquer 2 graph is in the cam only dyno thread.
Old 08-10-2007, 11:34 PM
MVDCGTO's Avatar
TSP says the V3 is good for 10-15rwhp, I think, over the V2 and better midrange. PS if you want a V3 I have one in the for sale section.
Old 08-11-2007, 01:15 AM
pHEnomIC's Avatar
v2 kicks ***, v3 kicks a lot of ***
There are more factors to the cam other than lift and duration.
The v3 has the lsk intake lobes which are supposed to have very aggressive valve events.
Old 08-11-2007, 11:06 AM
So i am guessing that the aggressive ramp rate on the lsk would givwe you the better mid range, due to higher lift sooner?
