what kinda numbers?
what kinda numbers?
what kind of e/t's and hp numbers can i be looking at here
52mmtb
tb bypass
lt4 intake mannifold
lt4 hotcam
tbi harris performance chip tuned for my specs
lt headers dumped
cold air intake egr delete
stock gears and stock auto trans
just was looking for an estimate or someone close to this
52mmtb
tb bypass
lt4 hotcam
lt headers dumped
How is it that people replied and failed to mention the LT4 intake he wants would be no gain? Milling it to fit LT1 heads destroys any potential worth it has. Internally it is the same as the late LT1 intakes.
Also that the stock gears and a stock stall would be a BIG mistake.
EGR delete is worth exactly zero HP.
All this bad info gets spread around beause people just answer the question rather than setting the noobs straight.
In my oppinion I'd say if you were going into the motor to do a cam swap, and couldn't afford a whole rebuild I'd look into getting the heads/intake ported and put a cam in at the same time. Then do LT's, TB, and Dyno test it to see what #'s you get. You could always do it that way and if ever need be you could do the bottom end later and you'd have a pretty stout street car. Also I'm not exactly sure so don't quote me on this but check into a custom grind cam...I heard they offer more gains... Good luck with the mods. JAMES
If a noob posts a thread to the effect of "does this combo work?" and it clearly doesn't, then by all means I have no problem setting them straight. Otherwise, I figure if there is something "off" in their setup and it will take longer than a few sentences to explain it, they will probably figure it out or they can post a question pertaining to that.
Nothing wrong with showing a little tact to the noobs. Besides it's not like there is always one right answer. Even experts frequently disagree.
Do you disagree on the LT4 intake?
Do you think stock gears, stock tranny which sounds like it means stock stall, are the right parts?
These are not parts that there are differing opinions on. It is fact the LT4 intake is internally the same.
It is fact that a cammed car will drive and perform MUCH better with a gear and stall upgrade.
I made the mistake of cam before stall and gear, I do not like seeing people make mistakes even if I made them myself.
yea i agree a lt4 intake would be a big waste of time and money as they are like stated above internally the same. you would have to mod it to get it to fit and gain nothing for it.
i would try maybe some more research because there are IMO better choices out there than a lt4 hotcam as well. you will also want to address your valvetrain when doing any cam upgrade along with quite a few little details and "while i've got it apart" type stuff. and like stated above you're car will be much more enjoyable with gears and a stall. Good Luck.
well the only reson i put the cam in first is because i was doing the engine swap and already had the engine on the stand and so it would have been easirer to do it so i just put all that . so yea that make it a better reson? or still no cus im a real newbie so hook me up . and what else should i go to becasue right now im outrunning 98-02 ls1 camaros and t/a's?
lol, cam after stall and gears??
im doing heads and a cam, and more boltons without them yet :X
im putting them on as soon as i can drive to the shop though
id say definitely get gears, a stall, RRs... etc etc
