Intake Sponges
Old 08-16-2007, 08:23 PM
DropTopBird's Avatar
Default Intake Sponges
I just finished my LS6 intake a few days ago and I remembered that I didnt put new sponges on the intake after I took the old ones off. Will this hurt anything? Is there any thing I can do in place of that? Maybe a little of the red rtv right at teh front of the manifold? Thanks alot.
Old 08-17-2007, 11:33 AM
Bump...does anyone know anything about this?
Old 08-17-2007, 11:53 AM
tylerdj's Avatar
I'm guessing you're talking about the foam that is on the bottom of the intake?
Old 08-17-2007, 12:25 PM
bsf
bsf's Avatar
I intentionally left mine off to assist in drying the area between the valley cover and manifold when it gets wet. Knock sensors do not like water.
Old 08-17-2007, 12:30 PM
Z28LS1camaroguy's Avatar
What do you think they are there for in the first place
Old 08-17-2007, 01:03 PM
bsf
bsf's Avatar
To maintain a moist environment.
I took a different approach and used a little high temp grease between the knock sensor boot and valley cover in the hope of providing a more waterproof seal. I almost used red RTV to make damn sure no water got in the pocket.
Old 08-17-2007, 04:07 PM
Yes I was talking about the foam under the intake. I figured they were there to keep water from getting under the intake. The intakes on now and Id really rather not take it off again. I read about the red rtv around the knock sensors, but I didnt do that either. Would putting some at the very front of the manifold where it meets the valley cover help any?
Old 08-18-2007, 01:22 PM
back up
Old 08-18-2007, 07:08 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
EXACTLY.....
Old 08-18-2007, 07:33 PM
bsf
bsf's Avatar
Originally Posted by NHRAMAN
EXACTLY.....
After removing the fins on my LS6 intake so I could use my x-type vapor vent pipe I did not reinstall new sponges because I did not think it would matter. If I ever run into problems, I will post them.
Old 08-19-2007, 02:17 AM
Well Ive never had trouble with the knock sensors in the past. I figured that they were there to keep the water out from underneath the intake when it rains etc. Im thinking that now that theyre not there the water will be free to get under the intake because there is a small space underneath it (the space that the coolant lines are in). With water being free to get under there I think it will get into the knock sensors much easier. Im going to try the rtv and hope for the best. If not Ill just post it up when my knock sensors go bad.
Old 08-19-2007, 02:25 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
My FAST intake had nothing of the like on it.
Old 08-19-2007, 06:18 PM
Pontiacerator
RevGTO's Avatar
IIRC, they sit over the front and back crossover pipes, right? I remember having the impression that they were there to provide some insulation between the pipes and the intake. But I may not remember rightly ...
Old 08-19-2007, 06:25 PM
MikeSomething's Avatar
No way, They're there to prevent rain from getting to the knock sensors. Most guys take the rear one off so that if any rain did get in, it would run out the back instead of getting trapped in there. That's what I did, no problems.
Old 08-21-2007, 08:48 PM
cablebandit's Avatar
they are their for engine noise reduction...fact
Old 02-18-2008, 04:55 PM
connexion2005's Avatar
I left mine off on the swap and haven't had any problems since... I even still have the stock knock sensors at 118k. However I do recommend doing what I did and putting High-Temp RTV Gasket Maker fully around each knock sensor. That way even if water was under there it would not reach the knock sensors.
Quick Reply: Intake Sponges
