opti opotions
opti opotions
a buddys opti went out today and he was wondering what his options were as far as replacing it? He has a lt4 hot cam and most of the bolt ons. He still has warranty on the one that he bought from o'reilys, but dosent want to replace it with another cheap one. any info will help thanks.
MSD or Delteq. Those are both top of the line. Personally i went MSD and i'm very very satisfied with the results.
just warranty the one from orielys and get this http://www.bailey-eng.com/
with out the high voltage going through it, it will last alot longer
i am going to **** on my msd when i pull it off. going back to a factory opti. when a company, that builds 8 sec cars and other crazy setups, tells you the msd sucks before a dyno event. then during the dyno you have major spark issues. well after you changed the plugs, checked the wires, changed the coil and the ICM and the graph still looks like a bad 80's hair cut. i do belive you would hate a msd opti also, much like myself. i would be willing to try the delteq. also screw a dynaspark, if they don't want to make them for people to buy let them sell the design to someone who will fill the orders.
what company sells delteq? or where can i find one? so his options are to warranty the one he got from o'reilys and get the delteq or ltcc. Or he could just buy the msd. I really havent heard to much bad things about the msd. still a hard choice.
I personally would go with LTCC that bailey-eng.com sells. yes you pay 400 bucks for the harness and the box, you have to buy the ls-1 coils and wires, but have heard nothing but great things with there customer service and the way the system works. All Deltec conversion does is essentially put cadillac style coils on it. Same concept as LTCC but IMHO LTCC is the way to go since they are easy to mount, the LTCC box has built in timing retard for boost, nos what ever. Rev limiter too. If I end up doing the conversion it will be that. my 2 cents
Originally Posted by Captainofiron
get the MSD
the only people who have problems with it, either installed it wrong, or had problems with the o-ring.
http://web.camaross.com/forums/showthread.php?t=539869
now i am not saying the dragging is a issue , it just shows quality issues. my car was running lean , popping back firing and missing all the way up the rpm band from idle. we changed everything on the car that would effect it and checked the rest. the opti is the only other source. when i finish my install (of factory opti ) shortly i'll post the results. 7 meg sony camera and it can't take a better picture than that , up close bah
Originally Posted by 96lt1m6
gm opti?
