Magnuson dyno question
Old 08-30-2007, 09:09 PM
SS125's Avatar
Default Magnuson dyno question
Has anybody got any before and after dyno results for the Magnuson s/c. I can't find any in any of the threads.
Old 08-31-2007, 07:38 PM
BadMonkey's Avatar
I never got a chance to do a before dyno as I bought the car then sent it to get the kit while i was still gone, but my car after made 505RWHP/480RWTQ and 400RWTQ at 1700 RPMs. THis was also while I am having consumption issues and we are pretty confident that when its fixed we will gain a bit more. Thats at 7lbs of boost.
Damon
Old 09-03-2007, 11:30 AM
Ed @ Late Model Speed's Avatar
Here's a copy of Badmonkey's graph after the magnuson, CNC ported heads, and cam, with LT headers.
We didn't have our dyno yet when his car first came in, so we didn't get a baseline, but stock LS1 F-body's with an M/T usually see 300-325 RWHP.
SS125, I snet you an email with the requested information.
Ed
File Type: bmp
Old 09-03-2007, 10:53 PM
HMFDZ28's Avatar
Ed can you post a smaller attachment of the Dyno lol.
Old 09-04-2007, 05:08 PM
BadMonkey's Avatar
Here is the dyno sheet only a little bigger.
Old 09-04-2007, 06:29 PM
layz's Avatar
any sound clips of your car bad monkey with the supercharger on it yet....
Old 09-04-2007, 08:43 PM
BadMonkey's Avatar
http://www.youtube.com/watch?v=4fAS1070FBY
That's all I got until the oil consumption issue is done.
Old 09-05-2007, 06:30 PM
97 Z Me Go's Avatar
Ill be getting mine dynoed on the 14-15th of this month. I hope it puts down some good numbers. It feels healthy and doesnt like street tires one bit anymore. I put a 3.2 pulley on the car but I have to key the crank yet because im only seeing 5#s still according to the map sensor. The car is running a ms4 with prc stage1 heads so its not "blower friendly" by the books but ill see what happens. Its been street tuned with hp tuners 2 bar i got 23 degrees of timing with 93 pump gas no knock.
As for the video. Did you get a chance to run the car without the lid on ever. Good god is the blower rediculously loud!
Ill let you guys know when it gets dynoed chances are i will post in the dyno section ill try to remember this post tho.
Kyle
Old 09-15-2007, 08:26 AM
97 Z Me Go's Avatar
Well it went to the dyno. I never dynoed the car before but i made 574hp and 505ft-lbs. It was about 50 degrees out to!
Old 09-15-2007, 08:46 AM
BadMonkey's Avatar
Congrats, hope when my car gets figured out we will see some more numbers as well. Looks good, got a pic of your dyno sheet?
Old 09-15-2007, 09:47 AM
97 Z Me Go's Avatar
ya there is a thread in the dyno section i will get it up there later today.
Old 09-15-2007, 12:18 PM
HMFDZ28's Avatar
Nice numbers 97 Z . At what Psi are you running BTW. Though your graph showed I can deff hit the 550hp mark I wanted
Old 09-15-2007, 12:35 PM
97 Z Me Go's Avatar
its at 6 psi because of the cam.
Old 09-15-2007, 12:54 PM
farmdawg's Avatar
97Z and Damon, did you ever figure out your oil issues?
Old 09-15-2007, 01:00 PM
97 Z Me Go's Avatar
Well its a LS1 so its going to use oil : ) But All i did was take a hose from the rear of each valve cover and connected them and I am also running one hose from the pass side cover to the blower. There is some oil in the throttle body but its not sucking a quart in 100 miles like it did. Now its like 500 miles and a 1/2 quart which is pretty much what i was loosing N/A
Old 09-15-2007, 02:40 PM
BadMonkey's Avatar
Nope have not figured it out yet. I have done everything possible to determine what may or could be causing it other then tearing it down. Now its getting reviewed to make sure I did not miss something and then will get torn down to find the issue. I am disapointed rigth now I waited a long time and its still not right at the moment, and all the work was paid for months ago. I was hoping it would have been doen by now but I have a feeling it will be another 2 weeks before I get it back maybe, which is a huge let down. It's getting torn down now to find the issue. At this point I was planning on going to the LSx SHoot out but now its not happening. Just gonna have to wait and see how it all turns out I suppose.
Old 09-15-2007, 03:55 PM
HMFDZ28's Avatar
Badmonkey- Did you guys try a leakdown test yet????? Alot of time that can point out oil consumption issues.
Old 09-15-2007, 08:52 PM
BadMonkey's Avatar
Sorry about Hi Jacking this thread lol.
I did a leakdown test twice and Ed has done it twice once after the build and once while checking my work, I rerouted the PCV to a catchcan and vented to atmosphere, replaced valve seals, checked the blower's seals and gaskets (not much to check). I have fouled out at least 10 sets of plugs, and god knows how many quarts of oil. If I go into boost I start eating oil quick. Its gonna be my bottom end but I starting from the outside to make sure it was not something else, working our way down from the top end to the bottom. Hate to have it pulled all apart to find out it was something stupid up top, but I got a feeling its in the bottom end. It had new rings and bearings put in as well and was brushed. It did not start doing this until after the build. I just hope we find it soon this is killing me. I may may not see the numbers he is getting but we figure I should be up around 530 or so on the HP when I get it all figured out.
Old 09-17-2007, 11:55 AM
farmdawg's Avatar
Thanks for the update guys. THis is something I'm going to have to look into when I get home and get back to tuning my car as well, so I really do appreciate the info you are sharing here, it gives me some ideas as to what to check on my car.
Old 09-17-2007, 01:01 PM
Were you using oil too Mark? I don't remember you ever telling me that
Ed
Quick Reply: Magnuson dyno question
