What am I going to do with this.
Go have the water next cut off Going to run a distributor while you're at it? In another thread I had posted where the Vortec distributor is basically an opti. So I bet it wouldn't take much work to get it running (since it uses the same coil and icm).
Looks nice though.
Looks nice though.
I work at a machine shop and plan on removing the water neck. I'm going to start fabbing an elbow for a monoblabe. Hopefully there is still room to install a direct port nitrous kit and I may also have a set of spray bars installed in the intake for the second stage. As for as the distributer I've been using the MSD unit and it even made it thru a bad water pump.
Well no pics, but I just got some brodix heads that have been converted to run on the lt1. I hope to get some flow numbers in a week or two. Then I will be calling to get some numbers for a solid roller.
Originally Posted by jakesz28
Well I got some numbers over the phone today and they are not as good as I hoped for.
Intake
264 at .500
274 at .600
283 at .700
I will have the flow sheet in a day or two.
Intake
264 at .500
274 at .600
283 at .700
Intake
264 at .500
274 at .600
283 at .700
Intake
264 at .500
274 at .600
283 at .700
Okay I got some more numbers herre.
These are flowed at 28 on a 4.030 bore
int exh lift
195.4 133.5 .300
241.7 162.1 .400
264.5 183.6 .500
274.3 196 .600
283 203 .700
This is without a valve job and the heads as I receaved them. This is an old set of heads that I just got and for the price I can't really complain. I hope to get a little more out of them.
int exh lift
195.4 133.5 .300
241.7 162.1 .400
264.5 183.6 .500
274.3 196 .600
283 203 .700
