$@^%# My Kooks!!!
$@^%# My Kooks!!!
Ok I just got the 1 3/4 stepped tp 1 7/8 Kooks headers..
And well I can not get the driver side to go on! I have tried about everything other than pulling out the motor!
Has anyone else had a problem?
Any ideas?
PLEASE HELP!!!!
Any ideas?
PLEASE HELP!!!!
Tech Resident
What is causing the problem? Basically, what part of the car is keeping you from installing the header? Something has to be blocking it. If we knew where the problem resided, we'd be able to help you a little better. A description or even better, a picture, would help.
Best advice I can give you without any info about your problem is to make sure the header is standing straight up and you have at least 3 feet of ground clearance.
ok well its hitting were my oil filter would be (were the filter screws into) and on the K member.. I have ground on the k member were the metal comes together and is spot welded just to try and give me more room but it's like I need like 3 more inches..
Tech Resident
Did you try loosening the mounts and shifting the engine a little bit? I can tell you on my header install, the engine was actually crooked in the stock mounts! The engine had to be realigned.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
KOOKS and QTP keep popping up with problems...hmmm..wonder why-----grind the casting tab...remove filter...if steering linkage is in the way.unbolt it...and finally....lift engine a bit.after you loosen the mount of course...
Filter is out
Steering linkage is out
Ill have to keep lifting..... i guess...
well I'm going back out to the shop to see what I can do I have help on the way so maybe two heads will win this little fight with the header... but keep the Ideas coming please!
thanks
thanks
You get what you pay for..... sry (some people annoy me with statements like that) ... anyway, the only thing I could suggest would be a different angle. I was surprised how much I had to angle my headers to get them to slide in. I also had mine really close to the k-member, 3 inches sounds like alot but mine only needed a little suggestion to make room. Have you done poly motor mounts yet, that might be something to consider. Hope you get it figured out.
Originally Posted by BlackSS2001
Casting tab???
Filter is out
Filter is out
Yeah i took one bolt out and put a jack under the motor to make it lean to one side really far but nothing
you have to take out both bolts and raise the motor straight up.. way up.. just keep an eye on the hose on the PS pump. it can easily come off and dump PS fluid all over.
I had the same problem with my 1 7/8's kooks. I ended up trying a bunch of wried angles and it went in.. seriously take the header completely out and try really strange angles and directions.. I think mine slipped in standing almost straight up.
When I had trouble with my 1 3/4 George told me that they are designed to go in vertically tilted 90 deg and then rotate it into place. I was not able to get the car high enough to do this so I ended up unbolting the motor mount and jacking the motor to tilt it a bit and was able to get mine in, since the stepped are a bit bigger you could unbolt the mount completely and slide it forward to get the clearance and then put it back. Good luck to you and I hope you get it in soon, I love my Kooks and am sure you will too.
well I got it!!!!!!!
I had to take the alternator out so I could get the motor mount main bolt out.. then I had to unbolt the motor mount that attaches to the frame.. then I got the header to fit in.... it was well yeah a major pain in the @$$!!! to much for a header!
but it's in and sounds good.
thanks for all the help everyone!
ooo yeah I was just wondering if anyont elses headers hit the K member? or under the the car its self..
Congrats' on getting it in there finally. Too bad you had a hard time. It seems like these cars are hit and miss.
I have QTPs and had to do a little grinding but I'm finding maybe I had a collapsed tranny mount. I also think the last time I unbolted the engine from the craddle I didn't leave in the same place I started.
I wouldn't be suprised if you had a clearance problem with the larger primaries. I do hope it works out for you though.
Good luck.
Good luck.
^^ Yup congrats on gettting them installed finally, the more of a PITA it is the more you appreciate when its done tho... right? ha.
fwiw i put in stepped edelbrock headers and never had a problem they basically slid right in... there not SS tho
LS1TECH Sponsor
I think I talked to you this morning. Well sorry I did not see this earliar. I would have help in anyway possible. But for your troubles pm me your info and I will send you out some gear.
when we installed kooks on my friend 01 ss we unbolted steering linkage, loosened k member and used a pry bar between the k member for leverage. my buddy kicked the header right in from under the car while i pryed the k member up. as soon as it cleared, i ended up punching myself in the jaw on accident. lol
