Just got my Y Pipe on and....
Old 09-13-2007, 12:54 PM
aggiebutter's Avatar
Default Just got my Y Pipe on and....
First of all, the offroad Mac with the Magnaflow sounds KILLER! However, now that I have it on, sometimes in frist it gets slyggish. It studders a bit when I hit the gas, but then it takes off. Is this a tuning issue since I took off the cats?
Old 09-13-2007, 12:57 PM
Infantrymarine's Avatar
Only happens in first? What about when you mash it in any other gear, what happens then?
Old 09-13-2007, 01:01 PM
I get sucked into the back of the seat! No, in 6th, it sucks *****, but all of the other gears are ok for the most part
Old 09-17-2007, 07:12 PM
bummmmmmppppppppp
Old 09-17-2007, 07:32 PM
ONEBADASSWS6's Avatar
Is your Y-pipe hitting the exhaust at any point?? If so, it can set off the knock sensor, which will make the car feel sluggish as hell as the timing gets pulled back.
Old 09-18-2007, 06:37 PM
Umm, I'm confused by the last question. By exhaust, you mean...? The pipe bolts to my manifolds and then meets up with my Magnaflow exhaust. Can you clarify for a noob please?
Old 09-24-2007, 03:35 PM
to the tizzzop
Old 09-27-2007, 08:06 PM
hazard2k's Avatar
some y-pipes will hit the floorboards underneith the drivers seat. If this happens, the knock sensor will hear the noise and assume it is the engine producing it, so it cuts back your timing which means you will go nowhere real fast. When you hit the gas in first gear, do you hear a banging sound from under your seat?
Old 09-28-2007, 03:26 PM
I think this is the problem Thanks for clarifying
Old 09-29-2007, 08:33 AM
kokingSS's Avatar
ok so when getting exhaust system check for pipes touching the floorboards b/c it may cause problems?
Old 09-30-2007, 08:34 AM
hazard2k's Avatar
The pipe may not be touching the floorboard when you look at it up in the air. the problem is when you hit the gas and the engine torques to the side, making the exhaust hit. A few people put a stiffer engine mounton the drivers side to help this problem. Thunder racing also sells a rubber bump stop that attaches to the exhaust pipe.
-Jeff
