Just got my Y Pipe on and....
First of all, the offroad Mac with the Magnaflow sounds KILLER! However, now that I have it on, sometimes in frist it gets slyggish. It studders a bit when I hit the gas, but then it takes off. Is this a tuning issue since I took off the cats?
Umm, I'm confused by the last question. By exhaust, you mean...? The pipe bolts to my manifolds and then meets up with my Magnaflow exhaust. Can you clarify for a noob please?
some y-pipes will hit the floorboards underneith the drivers seat. If this happens, the knock sensor will hear the noise and assume it is the engine producing it, so it cuts back your timing which means you will go nowhere real fast. When you hit the gas in first gear, do you hear a banging sound from under your seat?
Originally Posted by kokingSS
ok so when getting exhaust system check for pipes touching the floorboards b/c it may cause problems?
-Jeff
