How to keep car cool with IC infront of condensor?
Old 09-21-2007, 07:46 PM
SPRAYED 01's Avatar
Default How to keep car cool with IC infront of condensor?
Im running an old QMP kit where you have to remove the fan shround and install the intercooler right in front of the condensor. As expected my car is getting really hot, especially with the a/c on.
Any tips on how i can cool my engine without the shroud there?
Could removing my underdrive pulley for a stock help with flow?
I can fit a fan on the IC, what do you think?
Alex
Old 09-22-2007, 12:59 AM
SPRAYED 01's Avatar
Anyone running a setup like this. I know its not the best and the newest but i think it can work. Just need some ideas on how to keep the motor running cooler. Normal driving in any temp is perfect around 200-205. If i run the a/c for 15 in traffic and 80+ it will get to 240-250. Or if i beat the hell out of the car it will get to 220.
Its not really bad so there should be a way to help out.
Any ideas?
Old 09-22-2007, 11:31 AM
2000 Tran Zam's Avatar
Maybe try some water wetter in your coolant... supposed to cool it off by 20*'s I think.
Old 09-22-2007, 08:57 PM
SPRAYED 01's Avatar
I did that, did nothing. Today i replaced my fan motors, took out the condensor and cleaned the **** out of it, and put on my stock balancer. Its a tad better but it will still over heat with the a/c on max and me beating on the car.
Old 09-22-2007, 09:10 PM
shoemike's Avatar
try having both fans come on at the same time at a lower on/off temp.
and up your turn off speed (highway driving)
assuming you have a tuning tool.
Old 09-22-2007, 09:28 PM
procharged355's Avatar
yea I am right in there with my lt1 same temp #s no ac with front mount Sc could never figure it out besides just drive the car when it is 75 degrees or cooler
Old 09-22-2007, 09:32 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
A bigger radiator would definitely help! The BeCool ones are supposed to be pretty decent from what I've read on here. I plan on putting one in here as one of my next mods.
Old 09-22-2007, 10:55 PM
STALL UP's Avatar
You should go with the becool it has really helped us procharger iron block guys. With iron 408 F1R procharger FMIC and one Fan with the A/C on ideling in the drive for 30 min it never got over 190
Old 09-22-2007, 11:13 PM
Ping King's Avatar
see if you could put a better fan on. if the air isnt going through the rad to exchange the heat a larger radiator isnt going to help.
Old 09-22-2007, 11:14 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
You'll find some pics in this thread on the Be Cool radiator we did on my car.
https://ls1tech.com/forums/forced-induction/605648-solution-ati-heating-inpaired-cool.html
Old 09-27-2007, 11:11 PM
SPRAYED 01's Avatar
Is the "direct fit" be cool the real deal. I know alot of things say just bolt it in and its seems like thats never true. Im dont have much room to play with anymore so any heads up would be great.
Old 09-28-2007, 07:16 AM
smokinHawk's Avatar
why not fix the real problem and move the IC to the front of the nose of the car out of the way, not that hard or to expensive and will work allot better.
when i had my tti kit with inter cooler there IAT's were horrible, now with my new kit the temps stay low.
