Procharger rebuild(EPP)
Just got off the horn with ATI. A couple of fins on my impeller wheel have a chip or bend in them. Said it would be at least $1000 after which i soiled myslef.
So can i got to thinkin. Does anyone know how much just a head unit D1SC cost's? Or can I just put one of the F1 model head units on my D1 bracket and if so how much do they cost?
Any help would be greatly appreciated.
I just checked prices on F1A and F1C/R and they were 3,020 and 3,350 respectively.
The F1A has the same 9" volute as the D1SC, but the trans. is a little thicker. The F1C/R have a 9.75" volute, and the same trans. as the F1A.
I was told the F1C is a much better choice than the "R", because the r has a narrower efficiancy range (1500 rpm or so), and it has to be spun hard to reach it.
The F1A would be a very good upgrade from the D1SC also.
Steve
Steve
i have no problem rebuilding it myself if i can get the parts and there is no balancing involved....im just wieghin out my options cause i would like to spend money on other things such as a 9 inch rear and drive shaft hahaha
by the way I went 11.58 at 124.8 with a 1.80 60ft this weekend
