My 9in. is installed!!
I just completed my 9in. swap yesterday. It is a moser 9in. housing with 31 spline axle's and a tractin lock with 3.50 gear's! The swap was real easy. The backing plate's from the 10 bolt swap over,no problem,the stock driveshaft work's,you just have to change out the u-joint for the correct yoke. I have a the spohn torque arm that mount's to the underside of the body and not the tranny, and that even bolted up with realitively no problem's. So far so good.
I had another thread going where I asked if body modifications or alterations had to be done. They advised some slight tweeking of sheet metal to get the spohn torque arm (what I have) to fit with the 9 inch as it may hit the back seat support.
did you encounter this, or maybe, what did you have to do to get it to fit?
