243 Heads
Old 11-29-2007, 01:43 PM
GreatWhiteHype01's Avatar
Talking 243 Heads
Will 243 heads from the C5 Z06 mount on the 3.9" bore LS1 found in the 98-02 Camaro/Firebird? If so is there a substantial gain found in them over the 241 LS1 heads? I am looking at a set that are brand new LS6 heads (243 casting), Stage 1 ported by Livernois Motorsports. Assembled with stock LS6 valves, retainers and springs, stock chamber size. Any suggestions? Thanks. -Tom.
Old 11-29-2007, 01:45 PM
12secSS's Avatar
Those heads were first introduced on 2001 LS6 engines, so yeah they will work on an LS1 (3.89" bore). You should see about 10-20 hp increase with stock 243 heads over 241 heads. With ported ones, you can see as much as 25-30.
Old 11-29-2007, 01:56 PM
DANOZ28's Avatar
i think 98 heads have a different bolt pattern. but 99-2002 should be fine. the positive with actual vette heads is they come with light weight sodium filled valves (not sure if both exhaust & intake). however right now one of our sponsors is running a special on ls6 heads (w steel valves). i believe stock 241 heads flow about 245 cfm, stock ls6 flow about 265. and ported heads flow over 300 plus.
Old 11-29-2007, 02:10 PM
DANOZ28's Avatar
prt 2 i mistake i felt i made was not upgrading the ls6 standard springs to say patriot gold (good to 650 lift cams) if nothing else its added insurance.
Old 11-29-2007, 02:17 PM
Bad Blue WS6's Avatar
the different bolt pattern is the valve covers only.
Old 11-30-2007, 09:08 AM
radkon's Avatar
This may help:
Old 11-30-2007, 09:20 AM
LivernoisMotorsports's Avatar
The heads will bolt onto any LS1 engine, however as others have mentioned the '98 cars will require different valve covers and coil packs.
Regards,
Rick LeBlanc
Old 11-30-2007, 11:41 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Finally I'm going to save that graph for future newbie questions.
Old 11-30-2007, 12:47 PM
TARZAN's Avatar
Yes, they'll fit, and with a tune, they should provide noticeable gains.
-Will
Old 12-01-2007, 03:17 PM
Chucks1911's Avatar
Very helpful chart radkon. Thanks for posting it.
Old 12-01-2007, 05:55 PM
Jray67's Avatar
The hollow stem valves only cam in a few select years. 02-04 I believe, but don't hold me to those years. The recent 243 heads have solid valves. I have a set of 243 Stage I's from Livernois and they have solid stock LS6 valves.
Old 12-01-2007, 05:59 PM
Jray67's Avatar
Livernois is a great company with great customer service. I talk to Mike there whenever I call. He answers all my questions and he's as nice as can be. I highly suggest them. You won't be disappointed.
Old 12-03-2007, 12:06 PM
radkon's Avatar
You're right, the hollow stem valves are only in the LS6 Z06 package. The 243's in the GTO and later heads are solid.
I don't remember where I found that chart but its very helpful!
Old 12-03-2007, 02:53 PM
quiet_storm98's Avatar
stock heads dont flow that well...more like low 200's to 220 or so cfm
Old 12-03-2007, 03:08 PM
Thorny's Avatar
It looks like the one from GMPP's performance catalog. I believe they have the flow numbers for thier different heads on there as well. The website that I know its on isn't a sponser here, so I won't post a link,but it should be available elsewhere too.
Old 12-05-2007, 01:22 PM
Dokken's Avatar
Thumbs up
Thanks for sharing this info
Quick Reply: 243 Heads
