Progressive Vortech install with Pics and Q's
Old 12-27-2007, 08:43 PM
sworaz's Avatar
Default Progressive Vortech install with Pics and Q's
Started my Vortech G-trim install today and got a few hours in. I'm doing the install in a huge shed which is a plus but the floor is dirt which sucks. I will take pics of the install as I go for those after me who will be installing. I will also ask a question or two along the way.
Before start
Lid and Air ducting removed
Removed fans (from bottom)
Starting the power steering pulley puller (after I already broke it trying to use a 3 jaw puller )
Pulley removed
Resvoir removed (cracked it trying to part it from the pump, but have another one that was included w/ supercharger)
More to come tomorrow.
Old 12-27-2007, 08:57 PM
TT-TECH Veteran
Inspector12's Avatar
Looks good so far.Good luck.
Jeff
Old 12-27-2007, 09:09 PM
sworaz's Avatar
Thanks Jeff.
One thing I'm not getting is on the power steering pump there is a silver fitting on the left side (in pic) is this fitting supposed to be with the vortech kit? Can you just use the normal fitting that's on there?
Also what goes on top of the pump?
Old 12-27-2007, 09:20 PM
sworaz's Avatar
Is this the part that goes to the top of the power steering pump and goes to the bottom of the resevoir?
Old 12-27-2007, 10:19 PM
TT-TECH Veteran
Yes that is the fitting that goes into the top of the pump with a metal retaining clip that hold it in. and the other just goes on the bottom of the resivor with a clamp and don't for get the O-ring for the pump side. And yes that fitting is supposed to come with the kit and goes to the rack with another an adapter replaces the factory one.
Old 12-27-2007, 10:27 PM
sworaz's Avatar
I didn't get this fitting...can I just keep it the way it is with the stock one?
Old 12-27-2007, 11:58 PM
TT-TECH Veteran
There isn't enough room I don't think. That guy was a real mechanic huh? Man He ought to trade you out for your stock line. You can purchase those fittings from Earls I believe as they are a metric thread to a An fitting. Good luck.
Old 12-28-2007, 01:15 AM
sworaz's Avatar
Thanks.
I'll call vortech later today and see what size that fitting is.
Old 12-28-2007, 11:33 AM
Got Me SOM's Avatar
Jeff the guy that ripped the kit off has no idea.
Looks good so far sworaz just take your time.
Old 12-29-2007, 12:07 AM
sworaz's Avatar
So continued on today with the main objective of taking off the harmonic balancer, which turned out to be a tedious job. Being an auto, I had to start with taking off the starter...which wasn't hard, but holding the flywheel tight while my help cranked the bolt, was. To my surprise once i had a firm hold on the flywheel the two of them were able to break the bolt loose relatively easily.
We had three jaw pullers and after about 1 1/2 hours were sick, tired, and cold (Wisconsin winter air) of trying to get the puller to stay on the pulley under pressure. To our relief once I looked at the F-body service manual and saw how they positioned the puller, we had the crank off in a few mins. Lesson learned: Use service manual.
We also had a break with putting the new ATI dampner and AC pulley on...put some heat to it and it actually slid all the way on (surprised).
Then got to start trying to get the supercharger bracket on. Here's a couple pics.
Starter hanging to expose flywheel (yes I know the ground is dirt)
Positioning puller (not me, I'm taking the pic)
New ATI hub and AC on. Still have to get the rest of the pulleys on and torqued.
SC bracket on. Screwed for the moment until I figure out where to get the fitting for the power steering pump.
Old 12-29-2007, 08:22 AM
2001WS6Vert's Avatar
If you didn't pin the crank you should, otherwise the balancer will come loose.
Old 12-29-2007, 08:25 AM
Turbo LS1 SS's Avatar
nice baseball gloves
Old 12-29-2007, 12:07 PM
sworaz's Avatar
Might have to do that. Can you do it with the crank hub on like I have it in the pic? Surprised you can't just use a little bit of locktite.
Yes I have one baseball glove and one racquetball glove. 28 degrees burr.
Old 12-29-2007, 12:56 PM
TT-TECH Veteran
No your going to have to take the balancer off to pin it and the loctite is not going to help you at all.
Old 01-01-2008, 11:54 AM
sworaz's Avatar
Does anyone know if I will need to change the belt going from a 2.75 pulley to a 2.85?
Old 01-01-2008, 12:04 PM
Got Me SOM's Avatar
you should be ok, the tensioner will take up the slack.
Old 01-01-2008, 03:46 PM
sworaz's Avatar
Cool thanks.
Old 01-01-2008, 06:59 PM
sworaz's Avatar
The fitting where you tap for the oil feed, can you get this off without disconnecting the exhaust?
Old 01-01-2008, 07:07 PM
chewy99ws6's Avatar
if you are talking about the little nipple above the filter, you should be able to do it with the exhaust still on, I think it is a 8 or 10mm bolts.
Old 01-01-2008, 07:54 PM
sworaz's Avatar
We'll see tomorrow. Sucks having the car 25 mins out of town.
Quick Reply: Progressive Vortech install with Pics and Q's
