Progressive Vortech install with Pics and Q's
Before start
Lid and Air ducting removed
Removed fans (from bottom)
Starting the power steering pulley puller (after I already broke it trying to use a 3 jaw puller
Pulley removed
Resvoir removed (cracked it trying to part it from the pump, but have another one that was included w/ supercharger)
More to come tomorrow.
One thing I'm not getting is on the power steering pump there is a silver fitting on the left side (in pic) is this fitting supposed to be with the vortech kit? Can you just use the normal fitting that's on there?
Also what goes on top of the pump?
We had three jaw pullers and after about 1 1/2 hours were sick, tired, and cold (Wisconsin winter air) of trying to get the puller to stay on the pulley under pressure. To our relief once I looked at the F-body service manual and saw how they positioned the puller, we had the crank off in a few mins.
Lesson learned: Use service manual.We also had a break with putting the new ATI dampner and AC pulley on...put some heat to it and it actually slid all the way on (surprised).
Then got to start trying to get the supercharger bracket on. Here's a couple pics.
Starter hanging to expose flywheel (yes I know the ground is dirt)
Positioning puller (not me, I'm taking the pic)
New ATI hub and AC on. Still have to get the rest of the pulleys on and torqued.
SC bracket on. Screwed for the moment until I figure out where to get the fitting for the power steering pump.
Yes I have one baseball glove and one racquetball glove. 28 degrees burr.
