"How to" for Drill mod??
Old 01-17-2008, 01:40 PM
LS1C5Vette's Avatar
Default "How to" for Drill mod??
Is there a how to with pics somewhere? I got a 04 Slave so I assume it already is done? What about the master??
Old 01-17-2008, 01:56 PM
Black02SLPSS's Avatar
I believe the drill mod is done only to the master cylinder not the slave.
Old 01-17-2008, 03:34 PM
jmm98LS1's Avatar
The "drill mod" is actually not done to the master or the slave, you drill out the restriction in the braided stainless line that connects the master to the slave. There's a write up with pictures on installuniversity.com
Old 01-17-2008, 04:08 PM
Isnt the restriction on the master cylinder side of the line? Just curious..
Old 01-17-2008, 04:10 PM
TheLS1Kid's Avatar
Yep. Its on the master side.
Old 01-17-2008, 07:00 PM
LS1Tech Sponsor
Slowhawk's Avatar
No drill mod needed on a Vette.
Old 01-17-2008, 07:59 PM
98camaroLS1M6's Avatar
oh yeah, what's the reason for that?
Old 01-18-2008, 12:47 PM
stevensLS1's Avatar
factory race cars
Old 01-18-2008, 02:22 PM
LS1Tech Sponsor
Slowhawk's Avatar
The master is different than a F-body.You can't get to the line.
Old 01-18-2008, 03:53 PM
Tough Mudder
Hilton's Avatar
Careful you don't drill too far past the little metal clip. I must have nicked the inner wall of the braided line because I noticed it weeping fluid while I was bench bleeding it. I took it to Bearing Supply (a local shop) and had them cut off the ends and attach them to another braided / nylon lined line. Cost me $18, could have been a lot worse.
At least I know for damn sure there's no more restriction.
Old 01-18-2008, 03:55 PM
JonB's Avatar
Here's the link to the sticky at the top. Theres a link towards the bottom in the first post with a link to the write-up on the drill mod.
https://ls1tech.com/forums/manual-transmission/742741-sticking-clutch-pedal-write-up.html
Quick Reply: "How to" for Drill mod??
