Has anyone else had this problem?
Old 01-19-2008, 04:43 PM
BlackZ28629's Avatar
Default Has anyone else had this problem?
My car cuts out or off under hard acceleration. This problem is new and I believe it to be caused from the Ypipe banging the floorboard and interuppting the 02 signal or something of the sort. (new PS LT's and off road Y) It only does it when the pipe bangs, I think. Anyone have any suggestions? Bosch13111's...of course fixing the pipe bangin issue is being fixed but until then?
Old 01-19-2008, 05:26 PM
Unaffliated Racing's Avatar
It sounds like the banging is causing false knock and taking a bunch of timing out. Didn't I talk to you about some install work? This is Brian.
Old 01-19-2008, 05:31 PM
TheSilverOne's Avatar
correct
Old 01-19-2008, 05:55 PM
Grifter's Avatar
I agree with the y-pipe banging and setting off the knock sensors. Get some motor mounts and/or a anti-banging mount like the one Mufflex sells.
Old 01-20-2008, 01:50 AM
Yeah the false knock is what I thought it was...I was wondering if anyone else had that problem or if it was just me...good to know
Old 01-20-2008, 01:55 AM
1320 killer's Avatar
false knock is what it is. I had the same problem. weld a bracket on and be done w/ it.
Old 01-20-2008, 05:59 AM
jetlag's Avatar
+1..or go back to stock 1" thick exhaust pipe..that's how GM solved the problem
Old 01-20-2008, 06:23 PM
ha! forget that! 1" way too small...engine is actually breathing now!
