View Poll Results: What cam
MTI X1
11
24.44%
TR224 - 114
13
28.89%
TR227/224 - 114
1
2.22%
TR230/224 - 111
20
44.44%
Voters: 45. You may not vote on this poll
Final cam decision - Poll
Well, I have decided to throw a cam in and want some opinions. It is an 01' Z28 with 100,000 miles. Mods are Edlebrock Full length headers and y-pipe, and a free flowing cat back. Stock trans with a Yank 4000 stall converter (SS Series). Stock rear end with 3.42:1 gears. So far the best time with the car is 12.3 @ 108 MPH.
Cam choices are:
MT1 X1
TR224 - 114
TR230/224 - 111
TR227/224 - 114
Car gets cruised mainly around town but sometimes gets driven on long road trips 500+ miles. Sees the track maybe 3-4 times a year. Want some lope, but want it to be completely driveable and not have to worry about it dying out. Will most likely be bringing it to Speed Inc. to get tuned after installation.
What are your guys thoughts?
Also, based on what the car runs now, what do you think the new times will be after cam change? I want to be comfortably into the 11's. Is this possible with just the cam change to one of these relativley "smaller" camshafts?
Cam choices are:
MT1 X1
TR224 - 114
TR230/224 - 111
TR227/224 - 114
those are good cam choices. alot of people are very happy with the MTI X1 and the TR230. i myself have been really considering the X1. both of those cams are bad *** street cams for sure. search for a guy named gillbot. with a 4k stall, and midlength headers and the TR230/224 he put down like 399rwhp on stock heads!!
Thanks guys, this is a very interesting result. It's not really a one sided decision. I am really curious to find out where this ends up. Anybody have any ideas (1/4 mile performance wise) where the car will be at?
Once again, thanks for your guys input.
Futral F2. 224/224 112LSA
https://ls1tech.com/forums/dynamometer-results-comparisons/849642-small-cam-fms-f2-stock-heads-over-400hp-inside.html
can't go wrong. choppy idle, with near stock driveability.
LS1 Tech Administrator
Of the cams you listed, I like the TR230/224 the best. It makes the best power under the curve of the cams you listed. I'm also a fan of the X1. Excellent cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Thanks everybody for all your help. This Poll didn't really give me a definite answer, but after plenty of research I'm going to go with the TR230/224. I have not read one post (Out of alot) where anybody had a problem with this cam.
Instead of making another post, with this cam, can you guys help me with other things that go along with the installation?
What length push rods?
What Springs can I go with?
Car has 100K
Should I replace the oil pump even if it does have great oil pressure now?
Should I pull the heads and replace the lifters even though there is no sign of concern?
Car has 100K
Car has 100K
Car has 100K
I plan on swapping my pump with the ported ls6. I have 100k as well and also showing good oil pressure. When are you going to do this cam swap, I'm looking for the exact same things you are and I'm curious on your results.
Who sells this cam?
Thunder racing.
http://www.thunderracing.com/catalog...&vid=3&pcid=51
99-TR230/224-111 Thunder Racing Custom Camshaft
"Reverse Split" - 230/224 .575/.563 111 LSA 2200-6800 RPM Power Band. Excellent mid-range & high RPM power. Automatic cars require computer tuning and it is recommend for optimum results on manual transmission cars . Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended.
Would 7.425 pushrods be a good choice? For ybaslo1? 918 springs? Maybe...hopefully someone else will chime in. This what I'll go with until told otherwise.
Who sells this cam?
Who sells this cam?
Thunder racing.
So, 1.8 rockers are stock I'm guessing?
