PCV setup
PCV setup
I have a 98 TA and just switched over to centerbolt valve covers. I am going to run a Norris catch can and the valve covers I have just have a grommet for the pcv like the 5.3 trucks and tahoes run. What are my best options to hook up the catch can line to the motor? Should I just to run a pcv valve out of the grommet and then run the hose to the catch can or have some of you guys found an elbow that will do away with the pcv and allow you to run the line that way.
I was thinking of doing the LS6 conversion but it seems to have the same result as the stock pcv and I do not see the point of doing the LS6 and the catch can. Thanks for your help.
You need to pull vac through a PCV as stock, run 1 line from the catch can to the drivers side rear cover to suction the crankcase vapors, plug every other valve cover vent, get a small cleanable (K&N) filter, drill out the oil fill cap & press in a brass barb to slide the filter on to & you are set with a system that eliminates 90% of any intake oil contamination, has a good catch can to seperate the oil/water/blow-by gasses to liquid that can be drained, and no unfiltered fresh air source to wreck your motor over time (as far to many have with open hoses dangling). The system then pulls good vacum that is metered at idle & low RPM, and has plenting of filtered venting for the high RPM crank case pressure to pulse back w/out oil contamination into the air coupler/TB source.
I run a catch can and two separators. Admittedly, it's not as nice a catch can as yours, but it was still allowing oil vapor to sneak past. I have all but removed that now as the second separator has A LOT less residue in it than the first one.
Thanks for the input guys. I will run the pcv valve and then hook it to the catch can.
My AMX is my first true love but the TA has deffinately been more fun to mod with the wide variety of aftemarket parts to choose from.
I dump mine cause it tends to get water in it from time to time from condisation. I ran mine like this. I ran a line from teh back of the driver side, then ran off the back of the passenger side valve cover to a T where i connected the hose from the other valve cover then from that T to the Catch Can which I put in right behind my fog light. Mine has a drain on it and I drilled a hole in teh bottom of that plastic where i mounted the can so I can drain it without hoving to remove anything under the bumper. Then I plugged the front vent on the passenger valve cover and plugged the intake where it went in.
