PCV setup
Old Jan 22, 2008 | 08:32 AM
THE CHOP SHOP's Avatar
Default PCV setup
I have a 98 TA and just switched over to centerbolt valve covers. I am going to run a Norris catch can and the valve covers I have just have a grommet for the pcv like the 5.3 trucks and tahoes run. What are my best options to hook up the catch can line to the motor? Should I just to run a pcv valve out of the grommet and then run the hose to the catch can or have some of you guys found an elbow that will do away with the pcv and allow you to run the line that way.
I was thinking of doing the LS6 conversion but it seems to have the same result as the stock pcv and I do not see the point of doing the LS6 and the catch can. Thanks for your help.
Old Jan 22, 2008 | 08:33 AM
Bad Blue WS6's Avatar
not on subject, but kick *** AMX in your avatar.
Old Jan 22, 2008 | 04:23 PM
TLewis4095's Avatar
You need to pull vac through a PCV as stock, run 1 line from the catch can to the drivers side rear cover to suction the crankcase vapors, plug every other valve cover vent, get a small cleanable (K&N) filter, drill out the oil fill cap & press in a brass barb to slide the filter on to & you are set with a system that eliminates 90% of any intake oil contamination, has a good catch can to seperate the oil/water/blow-by gasses to liquid that can be drained, and no unfiltered fresh air source to wreck your motor over time (as far to many have with open hoses dangling). The system then pulls good vacum that is metered at idle & low RPM, and has plenting of filtered venting for the high RPM crank case pressure to pulse back w/out oil contamination into the air coupler/TB source.
Old Jan 22, 2008 | 04:52 PM
radz282003's Avatar
I run a catch can and two separators. Admittedly, it's not as nice a catch can as yours, but it was still allowing oil vapor to sneak past. I have all but removed that now as the second separator has A LOT less residue in it than the first one.
Old Jan 22, 2008 | 07:16 PM
TLewis4095's Avatar
2 are a good solution.....are they baffeled? For a crank case catch can to work it needs a baffel system in side it for more area for the gases to "bang" against the baffels or some other media (steel wool, etc.) to condense & seperate the vapors.
Old Jan 22, 2008 | 09:53 PM
Thanks for the input guys. I will run the pcv valve and then hook it to the catch can.
My AMX is my first true love but the TA has deffinately been more fun to mod with the wide variety of aftemarket parts to choose from.
Old Jan 23, 2008 | 12:43 AM
ae13291's Avatar
i did the SMH pcv mod! my pcv valve now runs after my catch can! it works great my filters have a little crud in them from oil trying to pass through!!
Old Jan 23, 2008 | 01:05 PM
ReFtheMC's Avatar
What does everyone do with the oil that is caught in the can? just dump it or put it back in the engine?
Old Jan 23, 2008 | 01:40 PM
yep,,i never even tried to mod my 70 Javelin,, but the TA gets all kinds of love!
Old Jan 23, 2008 | 03:41 PM
Viper's Avatar
"What does everyone do with the oil that is caught in the can? just dump it or put it back in the engine?"
Dump it
Old Jan 23, 2008 | 09:23 PM
BadMonkey's Avatar
I dump mine cause it tends to get water in it from time to time from condisation. I ran mine like this. I ran a line from teh back of the driver side, then ran off the back of the passenger side valve cover to a T where i connected the hose from the other valve cover then from that T to the Catch Can which I put in right behind my fog light. Mine has a drain on it and I drilled a hole in teh bottom of that plastic where i mounted the can so I can drain it without hoving to remove anything under the bumper. Then I plugged the front vent on the passenger valve cover and plugged the intake where it went in.
