Wasn't a spun bearing after all...
Old 01-29-2008, 04:17 PM
jpeach's Avatar
Question Wasn't a spun bearing after all...
To make a long stupid story short; I pulled the motor 99% of the way out of my car thinking I had a spun bearing and it turned out to be loose converter bolts.
It has 107k on it so I might as well refresh it while it's out. What all do I need to buy? I cant afford forged pistons and rods right now. So far I've thought of:
-ARP bolts
-Main and rod bearings- Any particular brand?
-Rings- Any particular brand?
-Timing Chain
-Gaskets
I'll probably through a cam in it but everything else should be ok left stock right?
Old 01-29-2008, 06:10 PM
LS1-450's Avatar
-ARP bolts
-Timing Chain
-Gaskets
may need to change the push rod length, depending on the cam
Oil pump
lifters
Might as well have the heads rebuilt while you're @ it
Old 01-29-2008, 06:32 PM
ls1leadfoot's Avatar
oil pump, lots of oil in a 107,000 lifetime
if you do a cam....new cam bearigs might a good idea
Old 01-29-2008, 07:33 PM
jpeach's Avatar
Default Weber stage 1 6.0L
What if I were able to scrape together $2,999.00 and buy this Weber short block? If I used everything I possibly could from my LS1 what could it cost me above and beyond the price of the short block?
http://weberracing.net/Engine-Type-G...duct_info.html
Old 01-29-2008, 08:01 PM
DaddySS's Avatar
This is why I say time and again, take the time to thoroughly analyze problems before tearing things apart.
Old 01-29-2008, 08:23 PM
jpeach's Avatar
I'm a believer... Wish I'd herd you say that before I f'd up.
Old 01-30-2008, 05:30 AM
jpeach's Avatar
Seriously, what would it take to accomplish this? Head gaskets, water pump gasket, oil pump... I could use everything else from my LS1 right?
Old 01-30-2008, 10:40 AM
blk00ss's Avatar
You can get a 30 short block from texas speed for like $2700.....and they are a sponsor.
Old 01-30-2008, 10:47 AM
chromeplated500's Avatar
i think i would stick it back in just like that.. if your really interested in a shortblock.. do some research and do it right...
