Oil Grade and Brand
Oil Grade and Brand
What viscosity of oil are you guys running? Right now I'm running 10w30 and my oil pressure when cruising and WOT is less than what I would like. I was just wondering what would be thicker and safe for me to run because I would like to get more than 40 lbs. of pressure when its hot.
I always use penz-url (penzoil) 10W30 in mine and haven't had any problems yet... You're oil pressure will change throughout your rpms, I say why not just stick to what works and is recommended..
Autozone is running a special on Castrol Syntec and Mobil 1 filters through March, 5th. You could get 5 quarts of German Castrol and a Mobil 1 filter for 25.99. That's a great deal.
Hey dude. I just read ur response on z28.com and I'm gonna get some tonight. Do they have like 5w40? spring is almost here. Right now it is 20 outside, but the car will be sitting a lot until it gets to about 50 or so.
The German Castrol will say Made In Germany on the back of the bottle. It will also say something like European Formula on the front of the bottle. I think the most important thing is that it says Made In Germany on the back. It's supposedly a Group IV full synthetic and is better than their American made 0W-30. The German Castrol is only available in 0W-30. I would run it year round and not worry about it. That's what I'm planning to run in my car whenever it's driveable. I run it in my Jeep. Check out bobistheoilguy.com. Those guys love the German Castrol. It's also supposedly closer to a 40 weight than a 30 weight. Another pretty good oil is Mobil 1 0W-40. I'm running that in my Jeep right now. But I haven't heard of any oil analysis done on that oil in the LT1.
I was running Royal Purple 20w-50 and I just went to Mobile 1 15w-50 on my last change. Then again, my motor is setup real loose so it needs a heavier oil. And I'm in south Texas so it rarely gets below 40 here.
Just because it's getting less oil pressure doesn't always mean it's worse, could simply mean the oil is going through the engine easier so it doesn't require as much pressure for it to go all the way through.
