3.42 Vs 3.73
Old 03-02-2008, 04:42 PM
ROWDYZ28's Avatar
Default 3.42 Vs 3.73
So a friend of mine just bought a 95 Lt1 and it has the stock 3.23's. Tried to find a thread on feed back about changing to 3.42 or 3.73 but came up short. He's got a stock A4 4l60e, drives a lot of hwy miles. Do you think 3.73 will be too much for the hwy. Be nice to find a site with a chart on both.
Anything helps..thanks
Old 03-02-2008, 04:43 PM
infinitebird's Avatar
I have 4.10s on my auto right now and it is way too much for the highway. I'm gonna swap it out to 3.42, I think that is the best auto gear if you have to drive a lot of highway miles.
Old 03-02-2008, 04:54 PM
ROWDYZ28's Avatar
I heard that 4.10 on a A4 was real bad..I just wonder if there is much of a difference between the 3.42 and 3.73 rpm wise.
Old 03-02-2008, 05:02 PM
with the 4.10 gears right now im around 2750 at 70mph, i calculated that with 3.73s it would be around 2500 and with 3.42s it would be around 2300.
Old 03-02-2008, 05:44 PM
ROWDYZ28's Avatar
cool..thanks man
Old 03-02-2008, 06:01 PM
StealthFormula's Avatar
I would just stay with 3.23's if I were him, I wouldnt be able to justify the cost of installation and gears plus new bearings etc. etc. just to go from a 3.23 to a 3.42 and for there to be a minimal performance gain. I would say go 3.73 without doubt but because of the highway driving I would just recommend your friend stays stock and puts the money elsewhere maybe into a converter which would be a much greater performance gain then upgrading to 3.42's and would not effect highway rpm's.
Old 03-02-2008, 06:24 PM
M6 Swap's Avatar
what do you think about going from 2.73s to 3.23s.?
Old 03-02-2008, 07:59 PM
Is your car A4 or M6 curious because of your username and what kind of driving do you do? 2.73's are amazing on the highway but so are 3.23's. I use to drive the turnpike everyday with my old LT1 that had 3.23's and I got good mpg and was very happy. There is definetly a noticible performance gain going from 2.73's to 3.23's but still some left out on the table.
Old 03-02-2008, 08:02 PM
M6 Swap's Avatar
its an A4, for now. i do almost all hwy driving.
Old 03-02-2008, 08:06 PM
porksoda's Avatar
If your doing an M6 swap then for sure throw in the stock 3.42's for a lot of highway driving.
Old 03-02-2008, 08:09 PM
1998_trans_am_ls1's Avatar
i have a 98 trans am a4 with 3.73s and i like the 3.73s i get about 2100 at 50mph
Old 03-02-2008, 08:11 PM
M6 Swap's Avatar
well the names a little misleading, originally i was gonna do the swap but i kinda gave up on it. its stayn auto, 3.42s?
Old 03-02-2008, 08:14 PM
BOLO's Avatar
3.73's/2800 stall is a good all around combo for both highway/street use. This is what I ran back when my car was my only daily commute.
Old 03-02-2008, 09:19 PM
Razor_Blade's Avatar
Here's a pretty cool gear calculator to play with. http://www.f-body.org/gears/ I may be showing my age, but I was playing with cars long before A-4 transmissions were available. A 4.10 gear with a 60E is not bad at all to me since I've taken road trips in cars that ran 3500 at 60 mph.
Old 03-02-2008, 09:38 PM
balzyz28's Avatar
Nice find^^
Old 03-02-2008, 09:48 PM
2.73s are garbage. that **** should never have been put in a performance car. upgrade to at least 3.42.
Old 03-02-2008, 11:50 PM
NorthernZ's Avatar
M6 with stockers(3.42)
My question is what kind of gains do you get out of gears? I know there good but what kind of good? I don't realy care about fuel but I don't want to run constent high rpms on the highway. I have access to 3.73's but sould I get 4.10?
Old 03-03-2008, 12:10 AM
for an M6 definitely 4.10s.
Old 03-03-2008, 01:22 PM
xxcoolrollinxx's Avatar
2.73's FTL
Old 03-03-2008, 02:08 PM
355z28's Avatar
I run 4.10's in a A4 definetly dont recomend for a hwy car. I eventually might drop to 3.73 gears. I really like the 4.10's around town and at the track, its ok taking the back roads to town, but nearly impossible to take on the interstate. if he gets a different daily driver and is going to keep the car for a weekend toy to go raise hell in id definely go with 4.10s.
Quick Reply: 3.42 Vs 3.73
