4L60E Transbrake complete!!!!!
Old 04-07-2008, 01:07 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Default 4L60E Transbrake complete!!!!!
We had been waiting for the custom Tranny pan to come in from Moroso so Circle D could start with the Transbrake install. I got the call last week and they knocked it out in a few days. Dave even installed an awesome tranny/rearend catch can to protect us from any extreme heat fluid burping. We definitely didn't want any fluids under the tires going down the track. He tied the tranny vent and rearend vent in together and mounted the catch can in the rear where it's safe and out of the way. I think it looks trick! The bottom of the car is filthy, but we are running dumped torque tubes and the carbon up the bottom pretty quick.
We went out to the track for some testing this weekend. The firt pass was at 4000rpm off the 2-step and holy cow it hit hard.lol. It never hooked solid, but the track was questionable and I was trying to get use to the new transbrake. I dropped it down to 3500rpm and then 3200rpm. It matched our footbrake 60fts a few times, but still spun a bit. It sounds nasty staging up. Once MadMan gets his hands on it we'll have her sticking.
Chris at Circle D built us a slightly softer hitting TC to keep us from putting the car on the bumper again. We definitely don't need that again.lol.
A special thanks goes out to the crew at Circle D!!!!!!
Old 04-07-2008, 07:23 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That trans pan looks really good. By "dumped torque tubes," I'm guessing you mean headers?
Old 04-07-2008, 07:29 PM
SSilverSSurfer's Avatar
is that Tq arm relocation kit intended for stock length tq arms? sorry to be off topic, that pan looks good
Old 04-07-2008, 07:50 PM
GregWS6&z28's Avatar
very nice. let us know how it helps ur 60'
Old 04-07-2008, 09:00 PM
TXCAMSS's Avatar
The torque tubes are just 18" extensions off the collector with turn-downs. They slide on and off as easy as the mufflers, but less weight
The TA relocation bracket is for the stock length aftermarket TAs and gets the TA off the tranny tailhousing as well as allows instant center adjustments.
I'd be surprised if the TB improved the 60ft much since we leave so hard off the footbrake already. I needed it to compete in heads up index races on a .400 Pro-Tree. That's where the $$$ is
Thanks guys!
Old 04-07-2008, 09:48 PM
10 & 11 Second Club
Caveman's Avatar
That Moroso pan looks great. I wonder if a trans brake on a 4L60 will hurt the durability of the tranny, I am running an Index class here in FL and a Tbrake would really help my RT on a Pro tree.
I cant believe you are using an aluminum driveshaft, I've broken 2 of the HD aluminum DS (but I'm 3685lbs).
Old 04-07-2008, 09:58 PM
TXCAMSS's Avatar
I don't expect the tranny to give because of the transbrake unless it shears an input shaft, but I hope we have that covered
The transmission operates just like stock exept the transbrake can be activated in Drive. I still stab and steer There is no holding the TB button to back-up or anything like that.
It's cool!
Old 04-07-2008, 11:01 PM
heymoej's Avatar
very nice! trans brakes are an awesome tool,if you can hook.............
Old 04-10-2008, 11:32 AM
Bryan @ Speed Inc.'s Avatar
I Want One!!!!
Old 04-10-2008, 12:38 PM
TXCAMSS's Avatar
The DS is actually a Dynotech Mixed Metal Matrix shaft. It's supposed to be a bit stronger than the aluminum units.
Old 04-10-2008, 09:21 PM
U LUZ's Avatar
James If you dont ever stop messing with your car im never going to catch up!!!
Old 04-10-2008, 11:29 PM
LS1curious's Avatar
Is this a redundant question ? what doesn't kill 4l60ez ?
I wonder if a trans brake on a 4L60 will hurt the durability of the tranny, (but I'm 3685lbs).
Old 04-12-2008, 07:18 PM
SSANIMAL's Avatar
where can you get a transbrake for a 4l60e?
Old 04-12-2008, 07:38 PM
BOLO's Avatar
TXCAMSS, is the T/BRAKE from Rossler? I thought maybe he was the one who designed this for the 4L60E.
Old 04-12-2008, 08:56 PM
TXCAMSS's Avatar
Yes it is a Rossler Transbrake. He is the only onr who makes them and has the patent on it for the 4L60/80Es. There's only a handful of people that can do the 4L60e transbrake install though. Circle D did my install and did me right! They are a sponsor and located in Houston -->
Old 04-13-2008, 07:47 AM
Circle-D's Avatar
We ordered it from Rossler and installed it for TXCAMSS. Very nice looking piece, a lot of R & D went into it. I spoke to Carl about it, very smart guy. A lot of stuff to get it working, not for the rookie.
Chris
Old 04-13-2008, 08:15 PM
BOLO's Avatar
How big of a stall are you running with this new t/brake? Are you manually shifting your 4L60E? or just set the shifter @ D? when utilizing the brake. Sorry with all this ?'s
Old 04-13-2008, 08:47 PM
TXCAMSS's Avatar
The current converter is a 4600ish stall and we are using a 2-step to get the right launch rpm.
We just put it in D and then Stab n Steer.
No problem with the questions.
Old 04-13-2008, 11:27 PM
daniel6718's Avatar
i wanna know how it holds up after about 20 passes
Old 04-14-2008, 12:54 AM
TXCAMSS's Avatar
LOL...well I've got 20 passes on it so far and this Saturday and Sunday we have our first points races for the year so I should have 20+ come Sunday.
Did you ever get your car to hook?
Quick Reply: 4L60E Transbrake complete!!!!!
