QA1 Double Adjustable Q's
Old 06-17-2008, 12:11 AM
Sinister95Z's Avatar
Default QA1 Double Adjustable Q's
I searched for about an hour and can not find an answer to my specific question, so I am hoping somebody runs a similar set-up and can help me out.
I just picked up a set of the HAL/QA1 24 way adjustable shocks. The shocks have both compression and rebound adjustment *****. I am going to run my stock front springs at about stock hieght, maybe slighty lower. I have already bought some of the BMR spring cups in order to make this happen. The car will be about 90% street and 10% strip. I have removed quite a bit of wieght from the front of the car by means of a UMI k-member, Spohn upper and lower control arms, ABS delete, bumper support delete, relocated battery, QA1 shocks and a couple of other small things.
I am looking for some good settings to start out with. Is it a good idea to adjust both about the same amount? I read that full soft is counter clockwise and full hard is clockwise. Is this correct?
Old 06-17-2008, 04:52 PM
I know somebody out there can help me...
Old 06-17-2008, 06:36 PM
INMY01TA's Avatar
yes counter clockwise is full soft and vise versa.
Old 06-21-2008, 08:20 PM
Thanks for the clarification. I could still use some help with a good starting point for the rebound/compression settings...
Old 06-21-2008, 10:57 PM
INMY01TA's Avatar
I've never used doubles but I would set the compression firm and the rebound somewhere in the middle as the "R" series shocks use a fixed firm compression. This is supposed to keep the front end from bouncing up and down I believe.
Old 06-22-2008, 01:14 AM
Thank you. That is the kind of stuff I was hoping to hear.
Old 06-22-2008, 02:02 AM
twitchtwice's Avatar
not to be negative but from what i understand the Qa1 are horrible for street.
Old 06-22-2008, 02:15 AM
99Bluz28's Avatar
Lightbulb
For the street try 6 clicks on compression, and 10 clicks on the rebound. That's a good starting point! IMO.
You want more rebound than compression for the street.
At the track you want more compression than rebound.
Old 06-22-2008, 07:54 PM
Perfect...thanks!
I understand that QA1's are not the best shock choice for the street. I wanted something that was going to work well on a 1/4 track and also be rebuildable. The double adjust QA1's seemed to fit the bill perfect. During the week when I am out cruising the streets, a decent ride is only a few clicks away. I figure if I can find a setting that works well for the street, it is still better than stockers.
Quick Reply: QA1 Double Adjustable Q's
