1dirtyZ V3.2 build (F2 procharger , 427, etc. )
Old 06-18-2008, 03:39 AM
1dirtyZ's Avatar
Default 1dirtyZ V3.2 build (F2 procharger , 427, etc. )
since its the off-season on this side of the world, i decided to go ahead and start the re buildup of my camaro ( that and the stang and the scout ) and document it here so i can keep a record of what i done.
my last season racing was horrible for this car, tons of issues that had to be tracked down and broken parts , so i decided to kinda start over.
here is a little background on the car: its a 99 camaro , 427 aluminum block , l-98 heads, th-400 , methanol injection , F1-R blower and front mount . basically a drag car now.
i've decided to upgrade / redo alot of things ( some i already started ), so i'll post pics as i go .
here's how the car started
Attached Thumbnails 1dirtyZ V3.2 build (F2 procharger , 427, etc. )-camaro-ground.jpg   1dirtyZ V3.2 build (F2 procharger , 427, etc. )-camaro-side.jpg
Old 06-18-2008, 04:20 AM
1dirtyZ's Avatar
here's what i'm planing on doing:
-light weight brakes
-travel limiter
-loose some weight
-redo the inside wiring ( basically gut the dash )
-new tranny coolers
-rebuild tranny
-new torque converter
-abs delete
-convert 6 point roll bar to roll cage
-swap out F1-R to F2
-fabricate cog drive
-install ati's blower super pulley
-lower 1-2 gears
-carb intake and elbow
-new intake tube
-tow hook
-fix cooling issue
-install crankcase evac.
-redo tranny cooler
-bigger injectors
thats what i can remeber for now
like i said, some stuff ( not much) , i already did , the others i'm just waiting for parts to show up.
Old 06-18-2008, 04:52 AM
EPP
EPP's Avatar
Sounds like you got a lot of work ahead of you? You should have a really quick car there. Bob
Old 06-18-2008, 05:00 AM
1dirtyZ's Avatar
i hope so , the best it ran was a 9.3 @ 144 with a burned up tranny .
hoping for high to mid 8's if not better
Old 06-18-2008, 05:35 AM
venom ws7's Avatar
Finally the beast will rise.
I really missed that car in the last rounds Sam but with 427 F2 the car will be back very strong.
Why L98 Heads??? What Intake will you use???
Old 06-18-2008, 05:55 AM
1dirtyZ's Avatar
i got a set of aerospace brakes for all four corners , that and with the abs delete dropped about 65 lbs if i remeber correctly off the nose.
i also ripped and redid the electrical wiring from bumper to bumper , in the bottom of the pic you can see the "nerve center" of the car , all electrical stuff goes there
i also gutted the dash and removed the carpeting for loosing more weight.
Old 06-18-2008, 05:57 AM
1dirtyZ's Avatar
also finished up the roll cage conversion , now that was a pain in the *** , definatly have some one do it for you if you can!
i also (finally) changed my 5 year old front runners ( VW bug tires) to M/T skinnies!
Old 06-18-2008, 06:17 AM
venom ws7's Avatar
Sam your best run was 146mph not 144mph
Loooooooooool
http://www.youtube.com/watch?v=geLu5TxrftQ
Nice work man good luck with the rest and keep us posted.
Old 06-18-2008, 10:05 AM
Gordon0652's Avatar
Going to be a sweet build!
Look into some heads that have a thicker deck.
Goodluck
Old 06-18-2008, 10:50 AM
Websy21's Avatar
Crazieness thats for show! You had the entire car gutted/ripped apart, haven't seen one like that before, must have took forever. I also have heard roll cages are fun to install Will be a beast, good luck and let us know how she makes ou!
Old 06-18-2008, 08:24 PM
1dirtyZ's Avatar
loo, thanks venom ws6 , i don't think i even saw that vid before
i used the L98 heads cause of their flow ( something like 360 cfm on the intake side , and quite a bit on the exhaust - thats alot compared to the patriots i had on there before).
the car has the l-76 intake on it , but i will be swapping it to the GM performance carburator intake and elbow.
like i said , this season was just bad. the blower took a carp, electrical problems all over the place , tranny slipping, you name it i had it but on the positive side , the stang really shined ( i'll be starting a thread regarding the build of that thing too )
gordon, thats the next plan , i'm also looking into an lsx shortblock in the near future ( i hope )
websy, the taking appart part didn't take that much, its the putting back together part that sucked , i got to give credit to the guys at SLR over here, they helped out with the wiring quite a bit !
and now that i look at the pics , GOD DAMN this camera makes the car look 10 times dirtier than it is !!!
Old 06-18-2008, 08:36 PM
1dirtyZ's Avatar
here's how the guages came out :
Old 06-18-2008, 08:55 PM
1dirtyZ's Avatar
i also finished relocating a few things: i relocated my water injection pump and tank for better access to the location you see here , you can also see the remote battery disconnect solenoid .
i also removed the factory radiator puke tank and relocated my battery to the trunk to make room for the new puke tank and Accusump.
i still need to plumb the accusump , i'm just waiting for a few fittings that should be here soon
Old 06-18-2008, 08:59 PM
venom ws7's Avatar
1DirtyZ IMO the L76 will kill the car and L98 Heads do flow very well compered to your old stg 2 patriot
But dont think afermarket casting will be bette with thick deck????
How much boost are you planning to run??? the F2 is a mean SOB I'm only asking to see if your worried about the head lifting problem.
And yeah I have a couple of vids of your car against TNTaddict
Old 06-18-2008, 09:00 PM
1dirtyZ's Avatar
i also removed the headlights ( ahhh, the things we do to loose weight ) and covered up the hole they left with black headlight covers. i had to fab a brace to hold them from caving in at high speed. their bottoms are screwed to the front bumper.
i'll snap a pic of that tommorow , but you can see part of the barace in the last pic.
Old 06-18-2008, 09:05 PM
1dirtyZ's Avatar
when i had the heads , the only option was either the truck intake or the l76. i have the carb intake now which should flow pretty well. i totally agree with you , thicker heads are a definate plus , but for now, i'll stick with the l98's till i get a 6 bolt block
as for boost, i'm looking for 20 psi ( the F1-R was maxed at 12 psi on this motor), if the tune is ok , head lifting shouldn't be an issue at that level .
do you have the complest run on vid?? ( does it show when i got sideways?)
Old 06-18-2008, 09:06 PM
trans2000am's Avatar
thats one dirty *** car when was the last car wash?
Old 06-18-2008, 09:19 PM
1dirtyZ's Avatar
funny you should mention that , it was washed about two weeks ago ( the car is garage kept) before i went to the track . but on the way there i was driving for 4 hours through a dust storm, and on the way back it was a SAND storm , there was san in every nook and cranny in that car !
this is the crap i had to deal with for 8 hours ! and to make it even more fun :35 mph cross winds !
Old 06-18-2008, 09:56 PM
wow.....
Old 06-18-2008, 10:19 PM
venom ws7's Avatar
Not the best vid but you can hear your car and see it going sideways
http://www.youtube.com/watch?v=0bNzWphdkiA
Good luck man and keep us posted 6 bolt will be even more sicker in the futuer
Oh how the hell did you maxed out F1R with 12psi and 408ci?????
Quick Reply: 1dirtyZ V3.2 build (F2 procharger , 427, etc. )
