C5 T56 in a Camaro?
Old 06-19-2008, 11:42 PM
dochall22's Avatar
Default C5 T56 in a Camaro?
Will this work? Somone told me that a corvette transmission would have different bolt holes? I dunno... knew to the stick stuff - will it need anything special to work?
1999 C5 going in a 2001 SS
Old 06-20-2008, 12:30 AM
78novacaine's Avatar
i know for sure that the shifter is mounted differently, being as how the c5 transmission is not bolted directly to the engine
Old 06-20-2008, 12:31 AM
dochall22's Avatar
whatta ya mean? so different bellhousing or something?
Old 06-20-2008, 09:03 AM
Black02SLPSS's Avatar
The C5 t56 wont work. It is mounted to the rear transaxle and the front of the transmission it mounted to a torque tube. The cases are different from each other.
Old 06-20-2008, 09:04 AM
Hugger Z's Avatar
The C5 trans is mounted to the rear differential and connected to the engine/bellhousing by a torque tube. So yes they are different. I am not sure if the bolt holes would still line up on the C5 trans and a F-body bellhousing.
Old 06-20-2008, 09:48 AM
01CamaroZ28's Avatar
Yep its different. I dont think you can make it work. I think they call the vettes a "floating" transmission if I'm not mistaken
Old 06-20-2008, 09:59 AM
thesource's Avatar
This has been covered several times . Do a search on it and you will find all the info you need to describe why it will not work .
Old 06-20-2008, 12:08 PM
85MikeTPI's Avatar
The internals could be put into an LS1 T56 with some extra $$, but yeah, the C5s don't sell for much because they only fit on a C5 transaxle drivetrain.
Quick Reply: C5 T56 in a Camaro?
