Help with poly mount install
i was wondering from anybody that has done poly motor mounts, how they got the top rear bolt out on the passenger side mount. the only thing i can get on the bolt is a box end wrench and there is no way that bolt is coming loose (its a 98).
i coated it with bolt breaker and am letting it sit overnight and will try again tomorrow, but did anyone do this with sockets and a u-joint?
just looking for something that will help me finish this install.
by the way i have pacesetter longtubes, if i cant get it out any other way im going to have to drop my exhaust and i really dont want to have to order some new gaskets.
any help appreciated.
I feel for you man. I was going to change mine out until I saw how much of a bitch it was with everything in the way. Can you possibly remove the bolts from the cross member and then raise the engine a little to make more room?
I ended up waiting until I swapped out the heads. It's a piece of cake with no heads and exhaust in the way of course.
mine took me 10hrs with manifolds on...was able to get everything with a socket and u-joint adapter.
with LTs in, i can't even imagine the hassles and tight fit.
i say drop the exhaust
i jacked the engine up a few inches but the problem is that the header curls over the mount, so its hard to fit anything in there - even my hand. jacking the engine would make getting the mount out easier, but i have one more bolt before i can do that! ahhhh.
i really need a larger wrench or breaker bar but im amazed the 13mm wrench will fit in there to be honest, much less a breaker bar. it is rusted on so bad i was pulling my weight up off of the ground (~180 lbs) and it didnt budge.
thanks for the help, ill see what i can do.
P.S. - i knew this was going to be difficult, and i was prepared for pretty much everything except for this bolt. i wouldnt say its been smooth sailing, but i was ready for some hard work....but this is just ridiculous.
Restricted User
When I did mine, I also did rod bolts so I dropped the K member with the motor jacked up by the trans. Once the K member was out of the way they were pretty easy to reach. Just do rod bolts while you're under there.
