Need Help With Security
Old 07-16-2008, 04:09 PM
99corvette's Avatar
Default Need Help With Security
Ok I did some searching and didnt find anything with the same set-up i got. My VATS has been deleted from my PCM with HP Tuners. But when i get in my car sometimes and try to start it, the security light pops up and stays on for 3 mins untill i can start it. It has gotten to the point now to where it is every other time i get in it......
Old 07-16-2008, 04:11 PM
99corvette's Avatar
I have also heard that there is a relay somewhere behind the passenger kick panel under the glove box, and that was my problem....??
Old 07-16-2008, 05:21 PM
2001NBMZ28's Avatar
Not familiar with HPT but VATS is in the BCM too, thinking HPT settings only apply to fuel shut off portion? If the security light is coming on VATS isn't completely deleted. Someone correct me if I'm wrong.
Old 07-16-2008, 05:22 PM
99corvette's Avatar
Yep thats what i was thinking, but the key is only like a year old, so i think its the contacts on the cly. Is there a way to bypass that?
Old 07-16-2008, 06:12 PM
ItsNotStock's Avatar
Solder in a resistor into your ignition that matches the key.
Old 12-28-2008, 03:23 PM
99corvette's Avatar
Alright guys/gals. This is what i just did to fix mine. All i did was take the starter ignition relay out and jumped it with a wire. Cranked right up without a problem. The security light flashed while the car is running though.
Old 12-28-2008, 09:18 PM
robster's Avatar
what about the VATS bypass from ecklers? its 23.00
Old 12-28-2008, 10:45 PM
99corvette's Avatar
nope i didnt send 1 cent. Just got some wire laying around put 2 connectors on it and jumped the start relay
Old 01-01-2009, 01:23 AM
robster's Avatar
how and where
Old 01-01-2009, 11:02 AM
99corvette's Avatar
Old 01-01-2009, 12:15 PM
robster's Avatar
sweet. it cranked but only for about 3 seconds
Old 01-01-2009, 01:22 PM
99corvette's Avatar
oh ok. Then your PCM is shutting the fuel off. Can you here your fuel pump prime when you turn the key over?
Old 01-01-2009, 01:37 PM
robster's Avatar
yep. sure can
Old 01-01-2009, 01:54 PM
robster's Avatar
ok, i fixed it. thanks guys
Old 01-01-2009, 04:53 PM
99corvette's Avatar
What was it?
Old 01-02-2009, 02:23 PM
robster's Avatar
i wasnt thinking right when i wired in the resistors. instead of making them a complete circuit together, i was just making 2 parallels. my dumbass mistake there.
Old 01-02-2009, 03:03 PM
99corvette's Avatar
Oh ok! Well im glad i didnt have to do that. lol
