stok bottom end handle 100 shot?
no is that at the crank? cause with 462RWHP im sure im at about 510+ crank and then 100 shot would put me over 6.. also are there control boxes that would allow when armed for the nitrous to automatically spray at say 3500rpm at WOT? im in a 6 speed with 4.11s dont really want to have to waste time pushing a button...
To be honest..i have no clue, im guessing rear wheel power considering most are on a dyno when checking. And you need a window switch. It will operate your spray for you automatically. set on and off point. Might want to check out HSWs new controller, looks pretty sick
here is the thread link for the new controller we just debuted.
https://ls1tech.com/forums/nitrous-oxide/969326-new-microedge-nitrous-controller-hsw.html
has the features you are looking for plus a **** load more for a ridiculous price.
our dry plate with the interface controller (which is also on sale) and the micro edge controller would be one SICK combination. When developing the micro edge we knew this would make an extremely good system when combined with the plate and interface. the sum of these three components is what truly makes this a safe system. So many saftey features are built in to two very small units. window switch, lean/rich A/F shutdown switch, A/F adjustor, timing retard unit, multi gear lock outs, etc. all together with a dry shot which is naturally safer then a wet kit as there is no fuel entering the intake.
i was getting the tune and i was planning on boost in the future so i figured id just go SD from the start and the guy who tuned it has a good rep. so how would i go about using nitrous with SD tuning? also is the interface youre talking about the micro edge controller? or is it the controller for a/f timing cause damn kinda wish i stayed maf tuned after reading about how easy and good that a/f controller is...
i checked out that brute shot plate kit and it under wet shots? maybe i dont understand the difference between wet and dry shots but i thought when it is sprayed through a plate or anything before the intake then that would be considered a dry shot right? and wet shots are directly mixed with your fuel?
Yes you can use the micro edge with the wet kit. The interface is actually a good tool to have with a wet kit as well. You can pull timing with it and make slight a/f adjustments without having to pull jets.
I'm pretty sure I got the 19lb ones as that's what my recent purchase log on ws6store says. Although I could have sworn I got bigger ones...don't know what the duty cycle was either. But if I actually am running the 19lbs na will I need to upgrade for the wet kit? Or is it just a bigger pump? Also what is a good pump to get?
